lido Posted March 24, 2019 Share Posted March 24, 2019 Hello everybody. Considering PSTYLEMODE=0 (use of named plot style tables), how to select with AutoLISP all entities in current working space based on PlotStyleName criteria? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted March 24, 2019 Share Posted March 24, 2019 Look into DXF 380 and 390 group codes... Quote Link to comment Share on other sites More sharing options...
lido Posted March 24, 2019 Author Share Posted March 24, 2019 @marko_ribar Thank you for your answer. Here below are the results. ;;1 (vla-get-plotstylename(vlax-ename->vla-object(entlast))) ;;Return "Style_1" ;;2 (cdr (assoc 380 (entget (entlast)))) ;;Return nil ;;3 (cdr (assoc 390 (entget (entlast)))) ;;Return <ENTITY NAME: 2a253790> ;;??? Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted March 24, 2019 Share Posted March 24, 2019 (defun c:selnamedpstyle-Style_1 ( / dict stename ss ) (setq dict (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME")) (setq stename (cdr (assoc 350 (member '(3 . "Style_1") dict)))) (setq ss (ssget "_X" (list (cons 390 stename) (cons 410 (getvar 'ctab))))) (sssetfirst nil ss) (princ) ) HTH., M.R. 1 Quote Link to comment Share on other sites More sharing options...
lido Posted March 24, 2019 Author Share Posted March 24, 2019 @marko_ribar Yess. Thank you very much for your solution. Quote Link to comment Share on other sites More sharing options...
