GregGleason
Block Attribute Change - Almost There?
GregGleason
I have a routine that almost works.
I have attributes that I want to move and the last attribute is a copy/move.
I want to change the attributes of that last copied ATTDEF (so it's just one object).  Namely, the Layer, Tag, Prompt, and Height
This is what I have so far:
(defun c:zzz ()
; (setvar 'osmode 16384)
   (if (setq ss1 (ssget "_C" '(15.3 1.3) '(15.2 1.2) '((0 . "ATTDEF"))))
      (command "_.MOVE" ss1 "" "_non" '(0. 0. 0.) "_non" '(0. 0.0832 0.))
      (alert "MTEXT Not Found")
   );; End of if
   (if (setq ss1 (ssget "_C" '(15.3 0.96) '(15.2 0.95) '((0 . "ATTDEF"))))
      (command "_.MOVE" ss1 "" "_non" '(0. 0. 0.) "_non" '(0. 0.1093 0.))
   );; End of if
   (if (setq ss1 (ssget "_C" '(15.3 1.10) '(15.2 1.09) '((0 . "ATTDEF"))))
      (command "_.COPY" ss1 "" "_non" '(0. 0. 0.) "_non" '(0. -0.1614 0.))
   );; End of if
  (if (setq ss (ssget "_C" '(15.3 0.93) '(15.2 0.92) '((0 . "ATTDEF"))))
  ; Change tag to "TITLE-3"
  ; Change prompt to "Title Line #3"
  ; Change layer to "_CBAR"
  ; Change height to 0.0938
I am not sure how to change the attributes.
Am I close or do I have a ways to go?
Greg
Share this post
Link to post
ronjonp
For your last attribute that is copied, use (entlast) to get the ename.
Then use:
(setq o (vlax-ename->vla-object (entlast)))
This will convert it to a vla-object and the properties within are fairly self explanatory.
Quote
; IAcadAttribute: AutoCAD Attribute Interface
; Property values:
;   Alignment = 0
;   Application (RO) = Exception occurred
;   Backward = 0
;   Constant = 0
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000001e7a0c7ead8>
;   EntityTransparency = "ByLayer"
;   FieldLength = 0
;   Handle (RO) = "2AC"
;   HasExtensionDictionary (RO) = 0
;   Height = 0.125
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000001e055005f58>
;   InsertionPoint = (8.76264 0.740156 0.0)
;   Invisible = 0
;   Layer = "0"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   LockPosition = -1
;   Material = "ByLayer"
;   Mode = 16
;   MTextAttribute = 0
;   MTextAttributeContent = ""
;   MTextBoundaryWidth = 0.0
;   MTextDrawingDirection = 5
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 1086
;   ObjectName (RO) = "AcDbAttributeDefinition"
;   ObliqueAngle = 0.0
;   OwnerID (RO) = 1072
;   PlotStyleName = "ByLayer"
;   Preset = 0
;   PromptString = ""
;   Rotation = 0.0
;   ScaleFactor = 1.0
;   StyleName = "Standard"
;   TagString = "ASFF"
;   TextAlignmentPoint = (0.0 0.0 0.0)
;   TextGenerationFlag = 0
;   TextString = ""
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000001e055006bb0>
;   UpsideDown = 0
;   Verify = 0
;   Visible = -1
Edited by ronjonp
Share this post
Link to post
GregGleason
Thanks ronjonp.  I don't understand these objects and how to get or place data into them.  Is there a link you could point me to?
Share this post
Link to post
GregGleason
UPDATE:  I found a source and got some things happening.  Thanks for the point in the right direction ronjonp!
Share this post
Link to post
GregGleason
The code that I added:
   (setq ts (vla-get-tagString o))
   (princ "\nTag String: ")                      ; Print notice
   (princ ts)                               ; Print insulation string
   (vla-put-tagString o "TITLE-3")
   (vla-put-PromptString o "Title Line #3")
Greg
Share this post
Link to post
ronjonp
Greg
Glad you got it sorted 🙂
Share this post
Link to post
BIGAL
If you see vla-get in example code then in most cases you can do the opposite a vla-put.
You will find Dumpit.lsp to be your friend. You can though investigate some vla-get objects even further using the (vlax-dump-object obj) which is like doing a entnext method.
This will dump all the attribute info for a selected block
(setq obj (vlax-ename->vla-object (car (entsel "\nPick a attribute block"))))
(foreach att (vlax-invoke obj 'getattributes)
(vlax-dump-object att)
DumpIt.LSP
Share this post
Link to post
