waywardtz Posted April 10, 2019 Share Posted April 10, 2019 My company has a master .iam of an entire vehicle. I modeled an .ipt in a seperate file at the .ipt origin. I would like to set the location of the .ipt, so when I put it ini the master assembly, it's located at 0, 0, 0. Can I set this location in the .ipt? I started an assembly and mated the three planes to the coordinates the part is at in the assembly. It didn't move the part in the master assembly. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Lazer Posted April 11, 2019 Share Posted April 11, 2019 Rather than using the three planes you can use the center points it to the origin. The center point is in the origin folder. Quote Link to comment Share on other sites More sharing options...
sonata Posted April 25, 2019 Share Posted April 25, 2019 and maybe the .ipt is locked/pinned Quote Link to comment Share on other sites More sharing options...
