cat3appr
Autocad 3D 2019 no import XML coordinates?
cat3appr
hello
I'm on Autocad 3D 2019 and I can't find some coordinate systems I need to assign.  I have an XML file with the coordinates I can add to the library , I used this command MAPCSLIBRARYIMPORT but is not recognized in this version of autocad.
Anyone can help?
thanks!
Share this post
Link to post
Cad64
That's an Autocad Map 3D command, not an Autocad command.
I don't know much about XML files, but I'm pretty sure that plain Autocad can't import them.
Share this post
Link to post
cat3appr
ok so with Autocad (non map ) is not possible to assign coordinate systems, it is not possible to import XML files ?
Share this post
Link to post
Cad64
I'm not sure exactly what you're trying to do, but maybe this will help with the coordinate system: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-9CEED44E-E8D3-43FE-B4CF-D838379C7D78-htm.html
As for XML files, like I said, I'm pretty sure that plain Autocad can't do anything with them. I think you would need Civil 3D or Map 3D.
Share this post
Link to post
