cat3appr Posted April 10, 2019 Share Posted April 10, 2019 hello I'm on Autocad 3D 2019 and I can't find some coordinate systems I need to assign. I have an XML file with the coordinates I can add to the library , I used this command MAPCSLIBRARYIMPORT but is not recognized in this version of autocad. Anyone can help? thanks! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 10, 2019 Share Posted April 10, 2019 That's an Autocad Map 3D command, not an Autocad command. I don't know much about XML files, but I'm pretty sure that plain Autocad can't import them. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted April 10, 2019 Author Share Posted April 10, 2019 ok so with Autocad (non map ) is not possible to assign coordinate systems, it is not possible to import XML files ? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 10, 2019 Share Posted April 10, 2019 I'm not sure exactly what you're trying to do, but maybe this will help with the coordinate system: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-9CEED44E-E8D3-43FE-B4CF-D838379C7D78-htm.html As for XML files, like I said, I'm pretty sure that plain Autocad can't do anything with them. I think you would need Civil 3D or Map 3D. Quote Link to comment Share on other sites More sharing options...
