sett Tag as attribute value
samifox
hi
i have a drawing with attributes but they have no value. the displays text are the Tag names, so if I wrap them inside a block I see nothing.
is there any way i can see those text object if i wrap it with a block or as an xref?
Thanks
S
Not sure what you're asking. An attribute is like a variable name, it doesn't do much good until you assign a value to it. One of the advantages of attributes in including them in blocks and giving them values so you can distinguish the blocks. In other words, an attribute is not a text object, it's a place holder for a text object.
