cat3appr Posted May 25, 2019 Share Posted May 25, 2019 (edited) hello, I need to apply properties and add a letter to the remaining part of this depth axis, as follow:, please refer to the screenshots: the properties and the "-" and the letter "m" shall be substituted to the rest of the depth axes, using the ones in the yellow rectangle. I can do it manually but it will take ages, is there a quick way? - dwg attached - editing depth axes.dwg Edited May 25, 2019 by cat3appr Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 28, 2019 Share Posted May 28, 2019 Just search for adding prefix or suffix so many examples here. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted May 28, 2019 Share Posted May 28, 2019 What are the properties you need to transfer? How many numbers are there? Do they correspond to a coordinate, or can you create a UCS that will give you the proper coordinate? Will these labels always have the same set of properties, or do they vary from project to project? Can you create the "m" along with the tick and add the numbers later? If this is a chronic issue, and the conditions are right, you can save time by writing a little code. Quote Link to comment Share on other sites More sharing options...
