cat3appr Posted May 26, 2019 Share Posted May 26, 2019 Hello each time I publish a DWG I always need to reload the settings, even though I do this action 10 times per day. I didn't see any save setting option in the window, Publish: and then I always need to select the page setup from an older DWG ... is there a way to save the settings? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 27, 2019 Share Posted May 27, 2019 (edited) This is why I have custom plot routines. Just pick from menu and work every time. How many title block styles and printers. Edited May 27, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
cat3appr Posted May 28, 2019 Author Share Posted May 28, 2019 ok so each time i need to browse and select it? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 29, 2019 Share Posted May 29, 2019 Explain more what it is your doing model, layouts, selected layouts different title blocks, etc. Maratovich has a good plot routine. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 29, 2019 Share Posted May 29, 2019 If you leave it as default, it will use the current page set-up in the drawing. If you want to be sure you are using a proper set-up, create named page set-up(s) in the drawing and they will appear in that list. Quote Link to comment Share on other sites More sharing options...
