sandiegophil Posted June 3, 2019 Share Posted June 3, 2019 Hello, I am using the dwg to pdf plotter. I have objects on proper layers The layers are set to plot I have configured the dwg to pdf to 'Include layer Information' When I plot I only get layer 0 in the pdf. Any help, suggestions and assistance is appreciated. Thanks, Phil Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 4, 2019 Share Posted June 4, 2019 Never had a problem post dwg. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted June 4, 2019 Author Share Posted June 4, 2019 pdf_layers.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted June 4, 2019 Share Posted June 4, 2019 What version of AutoCAD are you using to make the pdf, and have you got proxy graphic enablers? My lowly version of AutoCAD shows the drawing consists of one ACAD_PROXY_ENTITY on layer 0. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted June 4, 2019 Author Share Posted June 4, 2019 Hello, Update to original post, I did not provide enough information. I am using Civil 3D 2018. I have attached a drawing and pdf. I am seeing the layers for the drawn objects but the layers for the surface do not populate. Thanks, Phil pdf_layers.dwg pdf_layers-Model.pdf Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 5, 2019 Share Posted June 5, 2019 It comes in as an ACAD_PROXY_ENTITY here. The Layers work when plotted to PDF after exploding. I would think Civil3D you shouldn't have to do that. But, it is Autodesk, so. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted June 5, 2019 Author Share Posted June 5, 2019 SLW210, Thanks for your input, I appreciate it. Yet another painfully inappropriate Autodesk side-effect. Quote Link to comment Share on other sites More sharing options...
