samifox
avoid selecting underlay
samifox
hi
i always put an xref as an underlay, and always accidentally select it. is there a way to avoid selecting it?
thanks]
S
Share this post
Link to post
SLW210
One workaround is to place the xrefs on defpoints layer and freeze layer 0.
If you put the xref on a locked layer it is non-selectable during a command IIRC.
Share this post
Link to post
Dadgad
Locking the Layer sounds like the better solution, and it is easily reversible.
Share this post
Link to post
SLW210
Both are easily reversible.
Though being on the DEFPOINTS layer, it would not plot.
Share this post
Link to post
ammobake
You could also just unload the XREF in the references window if it's not important to your linework.  When you're done working you would just right click and reload it.
-ChriS
Share this post
Link to post
