wimal Posted June 14, 2019 Share Posted June 14, 2019 How to stop this attached message. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 14, 2019 Share Posted June 14, 2019 You will need to fix the drawing. From Autodesk..... Quote Issue: When opening a DWG file in AutoCAD or inserting an external file as a block or external reference, one of the following messages is displayed: This application has detected a mixed version of AEC objects participating in this operation. or Failed to register DWS file support for eTransmit Loading AEC Base Extended. Causes: There are several potentail causes: Drawing was saved from a different version (usually newer) of AutoCAD. An appropriate object enabler is not installed to support the AEC objects. Files are being opened between Architectural Desktop and AutoCAD, or between AutoCAD Land Desktop versions. Solution: Do one of the following: Use the -EXPORTTOAUTOCAD command (or AECTOACAD) to resave the file. Install the needed object enabler. Open the file in the newer version of AutoCAD which last saved it. Use AutoCAD Architecture to open Architectural Desktop files, or revert to Architectural Desktop itself. In AutoCAD Land Desktop, use the Format/Explode setting in the Civil Batch Drawing Converter utility to resave the file. Quote Link to comment Share on other sites More sharing options...
