CADZealot
Running the lisp based on block name
CADZealot
Hi Everyone,
I have a three lisp to create layouts automatically for three different sheet size. (A1,A2 & A3). Right now I'm running the lisp separately for required sheet size. Instead of that can we run the lisp based on block name which i inserted for layout creation.
For Ex. If i inserted A2 block, then lisp will check the block availability (A1,A2 & A3) A2 is available now...so lisp for creating A2 sheet should be run.
Thanks in advance.
Share this post
Link to post
Tharwat
Hi,
You can use instead the functions initget & getkword for a dynamic way.
Hit THIS LINK.
Share this post
Link to post
CADZealot
Hi Tharwat,
Using that we can run the lisp from the options..but in that case we need to select the lisp based on inserted block.
Is there any other way to run the lisp automatically by available block name.
Thanks.
Share this post
Link to post
Tharwat
What I meant with my previous reply is that you can have one program asks the user about the block name then insert it if that block name is existed into the same drawing otherwise an alert message to inform the user is that the block name is not available.
(initget "A1 A2 A3")
(setq blk (getkword "\nSpecify block name to insert [A1,A2,A3:"))
(if (tblsearch "BLOCK" blk)
   ;;; then your stuff here to insert the desire block name once its available in drawing.
   ;; else alert a message to user.
Share this post
Link to post
CADZealot
Thanks for the Explanation,
I have checked that but i don't know exactly that how to modify that. could you please help me on this.
(defun c:123(/)
(setq blk (getkword "\nSpecify block name to insert [A1,A2,A3]:"))
 (C:A1)
  (C:A2)
  (C:A3)
  ;(alert "Hi")
(defun c:A1 (/)
  (alert "A1 Here")
(defun c:A2 (/)
  (alert "A2 Here")
(defun c:A3 (/)
  (alert "A3 Here")
Share this post
Link to post
Tharwat
Give this a go and let me know.
(defun c:Test (/ blk)
  (and (setq blk (getkword "\nSpecify block name to insert [A1,A2,A3]:"))
       (or (tblsearch "BLOCK" blk)
           (alert (strcat "Block name < "
                          blk
                          " > was not found in this drawing."
       (eval (nth (vl-position blk '("A1" "A2" "A3"))
                  '((c:A1) (c:A2) (c:A3))
Share this post
Link to post
ronjonp
@Tharwat
I did not read this whole thread but FWIW .. you could shorten up your eval code like so:
(eval (read (strcat "(c:" blk ")")))
Edited by ronjonp
Share this post
Link to post
Tharwat
Thanks Ron for your important note. :)
Although that I recommended the OP just to have these three routines as one but apparently they have their reason to go with one.
Share this post
Link to post
CADZealot
Thank you so much Ron and Tharwat,
It's working perfectly now.
Thanks Again:celebrate:
Share this post
Link to post
Tharwat
Good to hear that. :D
You're welcome anytime.
Share this post
Link to post
