Steven P
Entmake help
Steven P
Good afternoon,
I have been trying to use entmake to create a block which works sort of using this as an example:
(entmake '((0 . "BLOCK") (2 . "MyNewBlock") (70 . 64) (10 4.0 5.0 0.0)))
(entmake '((0 . "LINE") (10 0 0) (11 2 2)))
(entmake '((0 . "ENDBLK")))
(entmake '((0 . "INSERT") (2 . "MyNewBlock") (10 6.0 6.0 0.0)))
(this creates a block with a single line, simple for my question).
First question, I would like to use variables as the line points, but I don't know how to do that, google hasn't helped much and I can't think of anything else to try,
so
(entmake '((0 . "LINE")(10 0 0)(...
might become
(entmake '(0 . "LINE") (10 pt1 pt2)(....
Second question might be the same answer. I can rename the block after it is created (I think) - but it would be nicer to create it with the correct name to start with - what I am doing will create different blocks based on user input.
Thanks for any help or pointers, hope I have explained this clear enough
Share this post
Link to post
Tharwat
Hi,
An example:
(setq p1 '(0. 0. 0.))
(setq p2 '(2.0 2.0 0.0))
(entmake (list '(0 . "LINE") (cons 10 p1) (cons 11 p2)))
Share this post
Link to post
Lee Mac
Here's an existing example for non-attributed blocks:
;; Objects to Block  -  Lee Mac
;; Converts a selection of objects to a block reference.
(defun c:obj2blk ( / e i l n p s x )
    (if
        (and (setq s (ssget "_:L" '((-4 . "<NOT") (0 . "ATTDEF,VIEWPORT") (-4 . "NOT>"))))
                (while
                    (not
                        (or (= "" (setq n (getstring t "\nSpecify Block Name <Anonymous>: ")))
                            (and
                                (snvalid n)
                                (null (tblsearch "BLOCK" n))
                    (princ "\nBlock name invalid or already exists.")
                (if (= "" n)
                    (setq n "*U")
                (setq p (getpoint "\nSpecify Base Point: "))
            (entmake
                (list
                   '(0 . "BLOCK")
                    (cons 10 (trans p 1 0))
                    (cons 02 n)
                    (cons 70 (if (wcmatch n "`**") 1 0))
            (repeat (setq i (sslength s))
                (entmake (entget (setq e (ssname s (setq i (1- i))))))
                (if (= 1 (cdr (assoc 66 (entget e))))
                        (setq x (entnext e)
                              l (entget  x)
                        (while (/= "SEQEND" (cdr (assoc 0 l)))
                            (entmake l)
                            (setq x (entnext x)
                                  l (entget  x)
                        (entmake l)
                (entdel e)
            (if (setq n (entmake '((0 . "ENDBLK"))))
                (entmake
                    (list
                       '(0 . "INSERT")
                        (cons 02 n)
Share this post
Link to post
Steven P
Thanks,
Tharwat, that's about the only thing I didn't try yesterday!
Lee, once again, that looks like the work of a genius, I'll try it out today.
Share this post
Link to post
Lee Mac
You're welcome @Steven P, I hope it helps - if necessary, the program could be stripped back to a function which simply accepts a selection set of objects, a basepoint, and a block name, and then generates the corresponding block definition (and block reference) using entmake. Hopefully the posted code demonstrates the techniques for accomplishing this, though of course, feel free to ask if you are unsure about anything.
Edited by Lee Mac
Share this post
Link to post
