JackD
Changing the save path of a CSV created from LISP
JackD
Hi, I found the below lisp routine online which creates a CSV file containing the insertion point, handle, and name for all objects within a dwg. It currently saves the CSV to the same folder that the dwg is saved in, however when working within a CDE such as ProjectWise the folder can be a bit troublesome to locate on the 😄 drive. I'm not familiar with lisp routines, can someone show me how i would edit it to have the save path set to the desktop?
Thanks in advance
(defun c:BlockExtract (/ BE_ActiveSpace BE_DataList BE_CSVFileID BE_ActiveDoc BE_WriteLine)
   (setq BE_ActiveSpace (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))))
   (vlax-for BE_Object BE_ActiveSpace
      (if
         (= (vla-get-ObjectName BE_Object) "AcDbBlockReference")
         (setq BE_DataList
            (append
               BE_DataList
               (list
                  (list
                     (vla-get-EffectiveName BE_Object)
                     (vla-get-Handle BE_Object)
                     (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint BE_Object)))
                     (* (vla-get-Rotation BE_Object) (/ 180 pi))
   (if
      BE_DataList
         (setq BE_CSVFileID (open (strcat (vla-get-Path (setq BE_ActiveDoc (vla-get-ActiveDocument (vlax-get-acad-object)))) "\\BlockExtract.csv") "a"))
         (foreach BE_Item BE_DataList
            (setq BE_WriteLine "")
            (foreach BE_SubItem BE_Item
               (setq BE_WriteLine (strcat BE_WriteLine (vl-princ-to-string BE_SubItem) ","))
            (setq BE_WriteLine (strcat BE_WriteLine (vla-get-FullName BE_ActiveDoc)))
            (write-line BE_WriteLine BE_CSVFileID)
         (close BE_CSVFileID)
   (mapcar '(lambda ( att ) (cons (vla-get-tagstring att) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))
   (mapcar 'vlax-release-object (list BE_ActiveSpace BE_ActiveDoc))
Share this post
Link to post
Lee Mac
Change:
To:
"C:\\YourPathHere\\BlockExtract.csv"
Remember to use either double-backslashes or single-forward-slashes as path delimiters.
If you always want the path to be the user's desktop, you can use a function such as the following to obtain the desktop path:
;; Special Folder  -  Lee Mac
;; Queries the WshSpecialFolders collection for the specified folder
;; Ref: http://msdn.microsoft.com/en-us/library/9x9e7edx%28v=vs.85%29.aspx
(defun LM:SpecialFolder ( folder / res spf wsh )
    (setq res
        (vl-catch-all-apply
            (function
                (lambda ( )
                    (setq wsh (vlax-get-or-create-object "wscript.shell")
                          spf (vlax-get-property wsh 'specialfolders)
                    (vlax-invoke-method spf 'item folder)
    (if spf  (vlax-release-object  spf))
    (if wsh  (vlax-release-object  wsh))
    (if (not (vl-catch-all-error-p res))
        res
In this case, you would copy the above code to a new line at the end of the code for your current program, and then change:
To:
(strcat (LM:SpecialFolder "Desktop") "\\BlockExtract.csv")
Share this post
Link to post
Lee Mac
FWIW, the following will likely be significantly faster for larger drawings:
(defun c:blockex ( / csv dir dwg enx fnm idx sel )
    (setq dir (LM:specialfolder "desktop")
          fnm (strcat dir "\\BlockExtract.csv")
          dwg (strcat (getvar 'dwgprefix) (getvar 'dwgname))
    (if (and (setq sel (ssget "_X" (list '(0 . "INSERT") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
             (setq csv (open fnm "a"))
            (repeat (setq idx (sslength sel))
                (setq idx (1- idx)
                      enx (entget (ssname sel idx))
                (write-line
                    (strcat
                        (LM:name->effectivename (cdr (assoc 2 enx))) ","
                        (cdr (assoc 5 enx)) ","
                        (vl-princ-to-string (mapcar 'rtos (trans (cdr (assoc 10 enx)) (cdr (assoc 210 enx)) 0))) ","
                        (angtos (cdr (assoc 50 enx))) ","
                        dwg
                    csv
            (close csv)
;; Block Name -> Effective Block Name  -  Lee Mac
;; blk - [str] Block name
(defun LM:name->effectivename ( blk / rep )
    (if
        (and (wcmatch blk "`**")
            (setq rep
                (cdadr
                    (assoc -3
                        (entget
                            (cdr (assoc 330 (entget (tblobjname "block" blk))))
                           '("acdbblockrepbtag")
            (setq rep (handent (cdr (assoc 1005 rep))))
        (cdr (assoc 2 (entget rep)))
        blk
    (setq res
        (vl-catch-all-apply
            (function
                (lambda ( )
        res
The formatting of the insertion point in the output is an odd choice in your program - I would have thought it would make more sense to separate the X, Y & Z coordinates into separate columns.
Edited by Lee Mac
Share this post
Link to post
JackD
Thank you Lee! I agree with your comment regarding separating the x,y,z values, but considering i didn't write the original function i wasn't sure how to change it.
Share this post
Link to post
