Sathya narayanan Posted August 7, 2019 Share Posted August 7, 2019 Can any body convert the below lisp which is in decimal feet system format which i require to be in metric system...? The below lisp works for Imperial cad template file well, but I require to function in a Metric template. I want a lisp to convert an elevation text (ex: El. 245.00) to El. 255.00 when I apply this command and move a relative distance of 10 m....? Hope I explained clearly... this would be very useful to me... (Defun c:BT() (Setq sst(ssget) sset(ssget "p" '((0 . "text"))) tv (cdr(Assoc 1 (Entget(ssname sset 0))))) (command "move" sst "" "@" "@") (setq lset (ssget "p" '((0 . "line")))) (Setq st 1) (while (= 0.0 (ATOF (substr tv st 1))) (Setq st (+ 1 st))) (Setq et 1) (while (/= "\"" (substr tv et 1)) (Setq et (+ 1 et))) (setq str(distof (substr tv st (- et st)))) (command "copy" sset "" (setq a (getpoint "\n Specify the source point: ")) (Setq b(getpoint "\n Specify the Desitnation point: " a))) (if (< (- (cadr a )(cadr b)) 0) (command "change" (entlast) "" "" "" "" "" "" (strcat "EL. "(rtos (+ str (- (cadr B )(cadr A)))4 2)"")) (command "change" (entlast) "" "" "" "" "" "" (strcat "EL. "(rtos (+ str (- (cadr B )(cadr A)))4 2)""))) (command "Copy" lset "" a b) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 7, 2019 Share Posted August 7, 2019 Replace 4 with 2 and try again. Quote Link to comment Share on other sites More sharing options...
