LITOKARDO_BC
FLIP SELECT MULTI BLOCK
LITOKARDO_BC
Good day, I need help please. I got this autolisp, but it only works for a single block. I don't have the knowledge to adapt it and select multiple blocks. thank you very much for your attention.
; Flip block example - with (grread)
(defun C:fb1 ( / e enx g s k itm )
 (and
   (setq e (car (entsel "\nPick a block to flip: ")))
   (member '(0 . "INSERT") (setq enx (entget e)))
   (princ "\nPress [X/Y/Z] to flip the block <exit>: ")
   (while (not s) (setq g (grread))
     (cond
       ( (or (eq g '(2 13)) (= 25 (car g))) (setq s T) )
       ( (= 2 (car g))
         (and
           (setq k (cadr (assoc (strcase (chr (cadr g))) '(("X" 41)("Y" 42)("Z" 43)))))
           (setq itm (assoc k enx))
           (entmod (setq enx (subst (cons k (- (cdr itm))) itm enx)))
     ); cond
   ); while
 ); and
); defun C:test
Share this post
Link to post
BIGAL
If your happy to pick pick then change the entsel  by adding a while. Not sure but nothing happened when I ran the code, picked block xyz message came up and nothing after that.
(while (setq e (car (entsel "\nPick a block to flip: ")))
Share this post
Link to post
Emmanuel Delay
I isolated the user input (selecting multiple blocks, then typing X,Y or Z) from the rest of the function.
I removed the while loop.  You can always run the function twice or three times if you wish.
X,Y or Z is for all the selected blocks now
(defun fb1 (e g /  enx  s k itm )
  (and
    (cond
        ( (= 2 (car g))
          (and
    ); cond
  ); and
(defun C:fb1 ( / e i ss g)
  (princ "\nSelect blocks to flip: ")
  (setq ss (ssget (list (cons 0 "INSERT") )))
  (setq g (grread))
  (setq i 0)
  (repeat (sslength ss)
    (setq e (ssname ss i))
    (fb1 e g)
    (setq i (+ i 1))
Edited by Emmanuel Delay
Share this post
Link to post
