ibrahem Posted August 31, 2019 Share Posted August 31, 2019 Hello, there, I want a help for a lisp that moves selected blocks to the nearest polyline and adding vertexes on it. thnx, Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 3, 2019 Share Posted September 3, 2019 Post a sample dwg before - after, this has been asked before to move block to pline, did you google or search here ? There are a couple of questions. use block insertion point or point in block rotate block square to pline inside or outside Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted September 9, 2019 Share Posted September 9, 2019 Something like this? Command MBP ;; test of (apv) (defun c:apv ( / p) (setq p (getpoint "\nPick Point for New Vertex: ")) (apv p) ) ;;----------------=={ Add LWPolyline Vertex }==---------------;; ;; ;; ;; Adds a new vertex to an LWPolyline at a point specified ;; ;; by the user; compatible with LWPolylines at any ;; ;; orientation, with varying width and arc segments. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2012 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Version 1.0 - 17-12-2012 ;; ;; ;; ;; First release. ;; ;;------------------------------------------------------------;; ;; based on Lee Mac's Add LWPolyline Vertex ;; http://www.lee-mac.com/addpolyvertex.html ;; I (Emmanuel Delay) isolated the user selecting of the point out of the function (defun apv (p / a b e h l n r w x z ) (while (progn ;; (setq p (getpoint "\nPick Point for New Vertex: ")) (cond ( (null p) nil) ( (null (setq e (nentselp p))) (princ "\nPoint does not lie on an LWPolyline.") ) ( (= 4 (length e)) (princ "\nObject is Nested.") ) ( (/= "LWPOLYLINE" (cdr (assoc 0 (entget (setq e (car e)))))) (princ "\nObject is not an LWPolyline.") ) ) ) ) (if (and p e (setq p (vlax-curve-getclosestpointto e (trans p 1 0)) n (vlax-curve-getparamatpoint e p) ) ) (if (not (equal n (fix n) 1e-8)) (progn (setq e (entget e) h (reverse (member (assoc 39 e) (reverse e))) l (LM:LWVertices e) z (assoc 210 e) ) (repeat (fix n) (setq a (cons (car l) a) l (cdr l) ) ) (setq x (car l) r (- n (fix n)) w (cdr (assoc 40 x)) w (+ w (* r (- (cdr (assoc 41 x)) w))) b (atan (cdr (assoc 42 x))) ) (entmod (append h (apply 'append (reverse a)) (list (assoc 10 x) (assoc 40 x) (cons 41 w) (cons 42 (tan (* r b))) ) (list (cons 10 (trans p 0 (cdr z))) (cons 40 w) (assoc 41 x) (cons 42 (tan (* (- 1.0 r) b))) ) (apply 'append (cdr l)) (list z) ) ) ) ) ) (princ) ) ;; Tangent - Lee Mac ;; Args: x - real (defun tan ( x ) (if (not (equal 0.0 (cos x) 1e-10)) (/ (sin x) (cos x)) ) ) ;; LW Vertices - Lee Mac ;; Returns a list of lists in which each sublist describes ;; the position, starting width, ending width and bulge of the ;; vertex of a supplied LWPolyline (defun LM:LWVertices ( e ) (if (setq e (member (assoc 10 e) e)) (cons (list (assoc 10 e) (assoc 40 e) (assoc 41 e) (assoc 42 e) ) (LM:LWVertices (cdr e)) ) ) ) (vl-load-com) (princ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Move blocks to the closest polyline and put a vertex there (defun c:mbp ( / blocks plines b pl p1 p2 i j min_dist pc) (princ "\nSelect blocks: " ) (setq blocks (ssget (list (cons 0 "INSERT")))) (princ "\nSelect polyline: " ) (setq plines (ssget (list (cons 0 "POLYLINE,LWPOLYLINE")))) (setq i 0) (repeat (sslength blocks) (setq b (ssname blocks i)) (setq p1 (cdr (assoc 10 (entget b)))) ;; insert point of block (setq min_dist nil) (setq j 0) (repeat (sslength plines) (setq pl (ssname plines j)) (setq p2 (vlax-curve-getclosestpointto (vlax-ename->vla-object pl) p1)) ;; closest point to polyline (from the inset point) (princ "\n") (if (or (= min_dist nil) (< (distance p1 p2) min_dist )) (progn (setq min_dist (distance p1 p2)) (setq pc p2) ;; closest point )) (setq j (+ j 1)) ) ;; move blocks (command "._move" b "" p1 pc) ;; put a vertex there (apv pc) (setq i (+ i 1)) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
