Lisp to select all Leaders by Type
MudawarCad
Dear all,
I'm looking for a simple lisp (probably vlisp) routine that can select all leaders of the same type (e.g dot). In other words, i only want to select the dot leaders of all my leaders in the drawing file.
Should look something like this:
(ssget "x" ("leader")) and ('leadertype 3)
Thanks
13 hours ago, BIGAL said:
Do you mean leader style dot?
(setq ss (ssget "x" (list (cons 0 "leader")(cons 3 "Dot"))))
I tried this, it gave me nil. If you can make what you have written work, I would definitely use it. Thanks for trying. I tried another method and it worked:
(vl-load-com)
(defun c:ABC ()
    (setq myss (ssget "x" '((0 . "LEADER"))))
    (setq myssArrow (ssadd))
    (setq myssDot (ssadd))
    (vlax-for object
        (setq ActiveSelSet (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-Acad-Object))))
        (setq myArrowType (vlax-get-property object 'arrowheadtype))
        (if
            (eq myArrowType 0)
                (princ "ARROW")
                (vlax-put-property object 'ArrowHeadSize 1.25)
                (setq myssArrow (ssadd (vlax-vla-object->ename object) myssArrow))
        (if
            (eq myArrowType 3)
                (princ "DOT")
                (vlax-put-property object 'ArrowHeadSize 0.6)
                (setq myssDot (ssadd (vlax-vla-object->ename object) myssDot))
    );vlax-for
Maybe a bit simpler.
; arrow closed fill is 0 Dot is 3 look at properties and count or run dumpit.lsp pick leader
(defun test ( / myss obj ahead)
(repeat (setq x (sslength myss))
(setq obj (vlax-ename->vla-object (ssname myss (setq x (1- x)))))
(setq ahead (vla-get-arrowheadtype obj))
(cond
((= ahead 3)(vla-put-arrowheadsize obj  1.25))
((= ahead 0)(vla-put-arrowheadsize obj 0.6))
(test)
Edited by BIGAL
  • Thanks 1
(cond
(test)
Works well.
Thanks, I appreciate the help.
