Oxters Posted September 4, 2019 Share Posted September 4, 2019 We have an issue that can be recreated easily. In a new document, if we create a leader object then copy it multiple times with the copy command then run the command (command "dimstyle" "a") and select all the leaders, their tails will all connect. It seems like a bug to me because the issue doesn't happen when we do the same thing but with copy+paste rather than the copy command. We are working on a lisp script that this issue is a problem to. Any help to circumvent this issue would be much appreciated. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 5, 2019 Share Posted September 5, 2019 Are you using AutoCAD 2008? What OS? What is the purpose for (command "dimstyle" "a")? Can you post what happens on the command line when you do this? What are your DimStyle settings? Quote Link to comment Share on other sites More sharing options...
Oxters Posted September 5, 2019 Author Share Posted September 5, 2019 We originally were using autocad 2006 on a windows 7 device. Then we tried on the same device with autocad 2015, same issue occurs. Later on a different device running windows xp with autocad 2013 it still happens. The command just applies the current dimstyle to the selected objects, you can recreate this issue with a new drawing and standard dimstyle. That's what we've been doing. We attached a video so you can follow along and try it as well: 2019-09-05 20- Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 5, 2019 Share Posted September 5, 2019 I can't recreate the problem on AutoCAD 2018 on Windows 7. Quote Link to comment Share on other sites More sharing options...
Oxters Posted September 5, 2019 Author Share Posted September 5, 2019 Thanks for testing it on your side. So does this mean this is a bug with older versions of autocad? Is there any way to apply a dimstyle through lisp while avoiding it if it is a bug? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 6, 2019 Share Posted September 6, 2019 (edited) Try save then dim a or re dim a not tested. Edited September 6, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
Oxters Posted September 6, 2019 Author Share Posted September 6, 2019 14 hours ago, BIGAL said: Try save then dim a or re dim a not tested. Just tested that out, unfortunately did not fix the issue. Thanks for the suggestion though. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 6, 2019 Share Posted September 6, 2019 Can you post a .dwg with leaders that are doing this? Quote Link to comment Share on other sites More sharing options...
Oxters Posted September 6, 2019 Author Share Posted September 6, 2019 7 minutes ago, SLW210 said: Can you post a .dwg with leaders that are doing this? Of course, Here's the before save: Before.dwg And here's the after save: After.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 9, 2019 Share Posted September 9, 2019 I get the same results as you on your Before.dwg. No time to dig into right now, I'll see if time allows a chance to dig through it later. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 9, 2019 Share Posted September 9, 2019 I added leaders to your .dwg and those do not connect. Seems it has something to do with leaders in the older AutoCAD. I copied your leader into a new drawing and they do not connect either. Quote Link to comment Share on other sites More sharing options...
Oxters Posted September 9, 2019 Author Share Posted September 9, 2019 Thanks for testing it out, so it seems to be a bug with the older versions of autocad. Hopefully there's some way to reset or something, like the save suggestion, that would help with the issue in the older versions. If I find something I'll report back. I really appreciate you taking the time to try and help. Quote Link to comment Share on other sites More sharing options...
