kiransai Posted September 12, 2019 Share Posted September 12, 2019 (edited) Hi there, I had tried using the LeeMac Layer Director V1.9 in autocad 2010. But the thing is everytime I need to enter the command "LDON" to run the lisp. Instead is there any chances of running the lisp itself by activating when new drawing file is opened without entering the command "LDON". Thanks in advance Edited September 14, 2019 by Cad64 Removed code and replaced with link to website Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 12, 2019 Share Posted September 12, 2019 (edited) Firstly, as requested within the terms on my site, I would prefer if programs were referenced by name or using a simple link to the original, rather than posting the entirety of the code on another site and would therefore appreciate if you edited your post to remove the quoted code. Regarding automatically enabling the program on drawing startup: this may be achieved using any of the methods I describe here; I would personally suggest that you create an AutoLISP file with the filename acaddoc.lsp saved within a trusted AutoCAD support file search path (or modify such file if it already exists), and populate this file with a load expression such as: (load "LayerDirectorV1-9.lsp" nil) Assuming that my Layer Director program has also been saved to a trusted AutoCAD support file search path. Edited September 12, 2019 by Lee Mac 2 1 Quote Link to comment Share on other sites More sharing options...
kiransai Posted September 14, 2019 Author Share Posted September 14, 2019 Thank you very much Lee Mac, I had followed the instruction but doesn't worked. Any other ways or is there any changes in the lisp so that it could work whenever a new dwg file is opened. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 14, 2019 Share Posted September 14, 2019 10 hours ago, kiransai said: Thank you very much Lee Mac, I had followed the instruction but doesn't worked. Any other ways or is there any changes in the lisp so that it could work whenever a new dwg file is opened. Before asking for more help, you should go back and read Lee's reply again, especially the part about editing your post to remove his code. Quote Firstly, as requested within the terms on my site, I would prefer if programs were referenced by name or using a simple link to the original, rather than posting the entirety of the code on another site and would therefore appreciate if you edited your post to remove the quoted code. Quote Link to comment Share on other sites More sharing options...
kiransai Posted September 14, 2019 Author Share Posted September 14, 2019 8 minutes ago, Cad64 said: Before asking for more help, you should go back and read Lee's reply again, especially the part about editing your post to remove his code. Yes @Cad64, I couldn't find any edit option for this post to edit, It shows this tread is being moderated. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 14, 2019 Share Posted September 14, 2019 38 minutes ago, kiransai said: Yes @Cad64, I couldn't find any edit option for this post to edit, It shows this tread is being moderated. Hmmmm, that's odd. Maybe it's because you only have 4 posts that you can't edit. Once you get to 10 posts you should be able to edit your posts. I have removed the code and added a link to Lee's program on his site. Quote Link to comment Share on other sites More sharing options...
