itacad Posted September 16, 2019 Share Posted September 16, 2019 Sorry, it is certainly a topic already discussed everywhere but I have not found a clear answer: is it possible to plot a pdf file without the edges and without creating a special sheet each time? For example I have a PDF sheet dimension 941x3000mm, and to hurry, I use it for all prints smaller than it, then with programs to manipulate the pdf I remove the white edges. It is faster to do so than to create a special sheet of the same size as the print I have to perform. Thank you for any clarifications Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 17, 2019 Share Posted September 17, 2019 Not really sure what it is your trying to do can have preset pdf sizes using say a menu. Quote Link to comment Share on other sites More sharing options...
maratovich Posted September 17, 2019 Share Posted September 17, 2019 Watch it (you can without a sound) - https://youtu.be/canvyK0IOpA Quote Link to comment Share on other sites More sharing options...
itacad Posted September 18, 2019 Author Share Posted September 18, 2019 Thanks for the video, talk about what I would like to solve and that is to have to create each time a "sheet" of the same size as the print area I select... For the physical plotter I created a single sheet as high as the paper roll and 3m long...in the plotter settings there is the option to print only the inked area so with a single sheet I can make us practically all the prints I need without wasting paper. I select the print area I select the plotter I select the only sheet that I can always go well without taking measurements I print Why isn't it possible with PDF printing and every time I have to make a special virtual sheet to get a borderless print? Regards Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 19, 2019 Share Posted September 19, 2019 I think we need a lot more detail about what your doing, so your plotting to a sheet size that matches the object at a fixed scale is that right ? Like printing at 1:1 true size. a 100x100mm would go on a A4 sheet a 600x600 mm would go on a A0 sheet. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 19, 2019 Share Posted September 19, 2019 If I understand your issue correctly, you have plotting areas of arbitrary sizes, and every time you plot, you want to plot to a PDF size that matches the plotting area, not to a standard plotter size. In other words, you want to have a new, uniquely sized plotter for each plot, or a way to crop each plot automatically to its extents. I'm not sure how you would do that, although it might involve some code and the extents variable. If that's not your issue, please provide more information. Quote Link to comment Share on other sites More sharing options...
itacad Posted September 22, 2019 Author Share Posted September 22, 2019 Hi CyberAngel, You understood well. My hope is that it could be done with common autocad commands. I will continue to use a single very large sheet format and to remove the part beyond the margins with pdf editing programs. regards Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 23, 2019 Share Posted September 23, 2019 If you look at extmax and extmin this gives size of objects or if a area required again lower left upper right, than take into account scale you can get the best sheet that will fit from a range of sheets. Quote Link to comment Share on other sites More sharing options...
eldon Posted September 23, 2019 Share Posted September 23, 2019 Perhaps, if you plot from model space, you could plot 'Extents' Quote Link to comment Share on other sites More sharing options...
maratovich Posted September 23, 2019 Share Posted September 23, 2019 15 hours ago, itacad said: Hi CyberAngel, You understood well. My hope is that it could be done with common autocad commands. I will continue to use a single very large sheet format and to remove the part beyond the margins with pdf editing programs. regards Attach an example of your dwg file. Quote Link to comment Share on other sites More sharing options...
itacad Posted September 23, 2019 Author Share Posted September 23, 2019 Hello and thank you all for your interest in the subject and for the answers you are giving me. There is no need to send any files, although being confronted with drawings with unified squares is not rare! I give the example of printing with "DWG to PDF" and selecting according to the cases either the 2A0 format or the 4A0 format...with these 2 formats I cover the printing area of practically all the files that I have to print every day! I find it stupid, however, that the part of the sheet outside the limits I gave to the press is created... I realized that the right operation to have no margins is to create a special press sheet, but it is much easier to successively remove the margins from the created pdf. "Easy" is faster than "correct". However, I attach an example file. SQUADRATURE CARTIGLI.dwg SQUADRATURE CARTIGLI-Modello.pdf Quote Link to comment Share on other sites More sharing options...
maratovich Posted September 24, 2019 Share Posted September 24, 2019 What you are talking about is using half the world.All users use different formats.No problems. Printing is quick and convenient.Use it - Revers - Automatic batch printing a multiple format Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 24, 2019 Share Posted September 24, 2019 Why not print "Fit to Paper"? Any PDF if plotted/printed will still need to be on a standard size sheet, if only viewed on a screen I can't see what a little bit of white around the edge would be a problem. Still not sure what you want to accomplish, but sounds like you need a custom program to create custom non-standard sheets to accommodate varying size print areas. Quote Link to comment Share on other sites More sharing options...
itacad Posted September 24, 2019 Author Share Posted September 24, 2019 Quote because I would lose the scale I don't need a special program because what I have to change the pdf is enough, in the end it is only one more operation. Thank you all Quote Link to comment Share on other sites More sharing options...
