403 Forbidden
Lee Mac
Ah! I got the same error as you when posting AutoLISP code without syntax highlighting but as you can see above, HTML works fine. Puzzling!
I'm going to have to do some investigation...
So it looks like the error occurs when any AutoLISP is posted. I've tried in a code block with and without syntax highlighting and outside of a code block. In each case I got the 403 error.
There have been no software updates recently, so I'm guessing this must be a server issue.
(defun DETAIL_0 ()
   (setq SYSVAR_LIST (mapcar '(lambda (X)
     (list X (getvar X)))
     '("CMDECHO"
       "OSMODE"
       "ORTHOMODE"
       "HIGHLIGHT"
   (setvar "CMDECHO" 0)
   (setvar "OSMODE" 0)
   (setvar "ORTHOMODE" 0)
   (setvar "HIGHLIGHT" 0)
   (if (zerop (getvar "TILEMODE")) ;;make sure we are mspace
      (if (= (getvar "CVPORT") 1) (progn ;;we are in paper space!
         (alert "You must be in Model Space for this routine to function!")
         (exit) ;;hard abort!
   (if (zerop (getvar "WORLDUCS"))
     (command "_UCS" "_W"))
   nil
Another test...
(defun DETAIL_0 ()
     '("CMDECHO"
       "OSMODE"
       "ORTHOMODE"
       "HIGHLIGHT"
   (setvar "OSMODE" 0)
   nil
1 hour ago, CADTutor said:
Hi All, it looks like we've managed to fix this issue but I'd be grateful if you could try posting some code in this thread as a test to ensure it's a robust fix.
Thanks
(defun c:Hello ()
  (alert "Hello World")
(defun c:Hello ()
This is a part of what I posted:
;;; Measures distance between 2 points, along polyline
(defun c:lm (/ a b d e d1 d2 p pl oecho osn)
  (vl-load-com)
  (command "cmdecho" (getvar "cmdecho"))
In previous post, I copied the whole routine as regular text (without placing it in brackets wrapping) and got the error again. Then, I deleted a half of the routine - got the error. Only when I deleted most of the routine, it went through.
