Ajmal Posted October 16, 2019 Share Posted October 16, 2019 (edited) AutoCAD to excel From AutoCAD I will click one text and after that for I will measure one length That both things I need to excel 1. I will click one text that things I need to come one row in excel at the same time 2. I will measure one length that I need to come on next row 3. This thing I will continue Actually, this is for quantity take off from AutoCAD to excel Please help me Edited October 16, 2019 by Ajmal Quote Link to comment Share on other sites More sharing options...
devitg Posted October 16, 2019 Share Posted October 16, 2019 Please upload both , DWG and XLS Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 16, 2019 Share Posted October 16, 2019 Interesting using Google Autocad to excel 36 million. Autocad export attributes 587,000 devitg this may be a useful example to be saved in the downloads area. For Admin have suggested before need a excel subject catergory this would save lots of duplication. Quote Link to comment Share on other sites More sharing options...
Ajmal Posted October 17, 2019 Author Share Posted October 17, 2019 19 hours ago, devitg said: Please upload both , DWG and XLS MODEL.xlsx MODEL.dwg Quote Link to comment Share on other sites More sharing options...
devitg Posted October 17, 2019 Share Posted October 17, 2019 (edited) I got it, It is a must the xls be online?. or the LISP could give a XLS or a CSV , after you m end pick . Edited October 17, 2019 by devitg Quote Link to comment Share on other sites More sharing options...
Ajmal Posted October 19, 2019 Author Share Posted October 19, 2019 On 17/10/2019 at 19:38, devitg said: I got it, It is a must the xlsbe online?. or the LISP could give a XLS or a CSV , after you m end pick . if you can make active excel that will okey. 2 types of data same comment.. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 20, 2019 Share Posted October 20, 2019 Here is a simple answer uses pick point for distance and a csv file which you can open in excel. Change D:\acadtemp to a directory where you want the csv file to go to. (defun c:ajmal ( / fo txt pt1 pt2) (setq fo (open (setq fname "D:\\acadtemp\\ajmal.csv") "w")) (write-line "Size,Length" fo) (while (setq tent (entsel "Pick text")) (setq txt (cdr (assoc 1 (entget (car tent))))) (setq pt1 (getpoint "Pick 1st point for length")) (setq pt2 (getpoint "Pick 2nd point for length")) (write-line (strcat txt "," (rtos (distance pt1 pt2) 2 0)) fo) ) (close fo) ) Quote Link to comment Share on other sites More sharing options...
Ajmal Posted October 24, 2019 Author Share Posted October 24, 2019 I need this quantity at the same time in active excel Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 25, 2019 Share Posted October 25, 2019 Ah yes the answer is the $100 question, only joking, its not straight forward but it is achievable and again there are just so many answers to your question out there that do just that pick something in Autocad and put an answer in a Excel cell. This is why the csv is offered first as its simple. The excel answers always seem to come back with more requests for enhancements people like me offer solutions for free here, so Cadtutor should not be used as a I want for free. Start with getexcel.lsp. Again GOOGLE search here also, it may take say an hour but you will find what you want it is definitely out there. 1 Quote Link to comment Share on other sites More sharing options...
