Trying to add transparency to a solid hatch
MAREBER
Hello all,
I am having difficulty trying to add transparency to a solid hatch. I think that I have all the correct boxes ticked (image attached), but when I check via a print preview, it appears black solid. Not too sure why this is not working for me... any suggestions? THANK YOU so much in advance for any help.
+1 to SLW and also be aware that sometimes printing directly to a printer or plotter can fail with transparent hatches. I have found that it works best for me to print to a PDF 1st and then print this file to a printer/plotter. Good luck.
