Robertoooo Posted October 30, 2019 Share Posted October 30, 2019 Can i change object color in different viewports? Not entire layer color, just one object, even if there are other objects of the same layer which would not change color. Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 30, 2019 Share Posted October 30, 2019 Nope, you can change the color of an entire layer, in just a single viewport, but individual object colors are not limited to viewports they are the same everywhere. 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 30, 2019 Share Posted October 30, 2019 If it's in a block, you might give the object the ByBlock color. Then change the color of the block's layer as needed. But that's reaching. The other option, which is also reaching, is to put the object on its own layer. That creates a set of potential problems, including having to remember that there's a layer with only one object on it. Quote Link to comment Share on other sites More sharing options...
tombu Posted October 30, 2019 Share Posted October 30, 2019 One more option. Copy it in place then use CHSPACE to put the copy in Paper Space before modifying the color. Quote Link to comment Share on other sites More sharing options...
ammobake Posted October 30, 2019 Share Posted October 30, 2019 There are ways to "force" this to work but probably not for viewports on the same sheet since the plot styles are layout specific. You could create a color dependent plot style to do this, in theory but it's more work than its' worth when there are much simpler solutions. One option is to simply trace the polyline in paperspace (over the viewport) and make that the desired color. In other viewports the object color would remain unchanged. But in that one viewport it would be the color you are wanting. It's the easiest solution. You could also copy the "object" from 0,0 paste at 0,0. apply a different layer to the new object(s). disable the layers in your viewports so the correctly colored entities show up where you want. ChriS Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 31, 2019 Share Posted October 31, 2019 (edited) One of the guys I worked with did this changing layer colors and it took me ages to figure out what he had done, know now. More importantly why ? Edited October 31, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 31, 2019 Share Posted October 31, 2019 Bottom line is, there is no way to do it without replicating the object at least once, thus defeating the desire to not draw it more than once. Quote Link to comment Share on other sites More sharing options...
