jim78b Posted November 12, 2019 Share Posted November 12, 2019 is possible to have a lisp that put all entities that are on layer 0 lineweight to byblock? i have this code but put even other layers on setbyblock lineweight (vl-load-com) (defun c:bf (/ col cnt lop sel) ;;;--------------------------------------------------------------------------------------------------------------------- ; Dynamic blocks don't update and I dont know why. Vla-update doesnt work. Vla-resetBlock works but all dynamic parametres are lost. ;;; subroutines ;; remove duplicated items in list (defun LM:unique (l) ; by Lee Mac (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))) ;; set "by block" to all entities in block definition (defun BB:setByBlock (nam / blc blk) (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq blk (vla-item blc nam)) (vlax-for x blk ;;; (vla-put-layer x "0") ;;; (vla-put-color x acByBlock) ;;; (vla-put-linetype x "ByLayer") ;;; (vla-put-linetypescale x 1.0) (vla-put-lineweight x acLnWtByBlock) ;;; (vla-put-entityTransparency x "ByBlock:") ;;; (vla-put-material x "ByBlock") (if (eq (vla-get-objectName x) "AcDbBlockReference") (BB:setByBlock (vla-get-effectiveName x)))) ) ;;;--------------------------------------------------------------------------------------------------------------------- ;;; main (setq lop t) (while lop (princ "\nSelect blocks: ") (if (setq sel (ssget '((0 . "INSERT")))) (progn (setq cnt 0) (setq col nil) (repeat (sslength sel) (setq obx (vlax-ename->vla-object (ssname sel cnt))) (setq col (cons (vla-get-effectiveName obx) col)) (setq cnt (1+ cnt))) (setq col (LM:unique col)) (foreach x col (BB:setByBlock x)) (setq lop nil)) (princ "\nNo selection"))) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) (princ)) Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 12, 2019 Share Posted November 12, 2019 4 hours ago, jim78b said: is possible to have a lisp that put all entities that are on layer 0 lineweight to byblock? i have this code but put even other layers on setbyblock lineweight (vl-load-com) (defun c:bf (/ col cnt lop sel) ;;;--------------------------------------------------------------------------------------------------------------------- ; Dynamic blocks don't update and I dont know why. Vla-update doesnt work. Vla-resetBlock works but all dynamic parametres are lost. ;;; subroutines ;; remove duplicated items in list (defun LM:unique (l) ; by Lee Mac (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))) ;; set "by block" to all entities in block definition (defun BB:setByBlock (nam / blc blk) (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq blk (vla-item blc nam)) (vlax-for x blk ;;; (vla-put-layer x "0") ;;; (vla-put-color x acByBlock) ;;; (vla-put-linetype x "ByLayer") ;;; (vla-put-linetypescale x 1.0) (vla-put-lineweight x acLnWtByBlock) ;;; (vla-put-entityTransparency x "ByBlock:") ;;; (vla-put-material x "ByBlock") (if (eq (vla-get-objectName x) "AcDbBlockReference") (BB:setByBlock (vla-get-effectiveName x)))) ) ;;;--------------------------------------------------------------------------------------------------------------------- ;;; main (setq lop t) (while lop (princ "\nSelect blocks: ") (if (setq sel (ssget '((0 . "INSERT")))) (progn (setq cnt 0) (setq col nil) (repeat (sslength sel) (setq obx (vlax-ename->vla-object (ssname sel cnt))) (setq col (cons (vla-get-effectiveName obx) col)) (setq cnt (1+ cnt))) (setq col (LM:unique col)) (foreach x col (BB:setByBlock x)) (setq lop nil)) (princ "\nNo selection"))) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) (princ)) Are you trying to set all entities in all blocks to layer 0, color byblock, linetype bylayer and lineweight byblock? It will not work with dynamic blocks because you are finding the effective name of the block, not the name of the block. If the answer to the first question is yes then you need to iterate all the blocks in the block table (omitting layouts and xrefs). This should take care of the dynamic blocks. Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 13, 2019 Author Share Posted November 13, 2019 yes but if i set linetype by layer i have a layer for axis but the lisp put all to layer 0 and linetype of all lines will be as layer 0. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 13, 2019 Share Posted November 13, 2019 (edited) OK try one of these. The first is your original code corrected to to only set the lineweight of block entities that are on layer "0". I have moved the two sub functions outside the main function. This should also now do dynamic blocks and alters both the effectivename definition and the anonymous definition. This will only process the blocks in the selection set. The second (c:lwbb) iterates the block definition table and requires no selection set. Again it will set the lineweight of block entities on layer "0", but it will process ALL block definitions except XREFS, LAYOUTS and DIMS (as far as possible). The DIMS part needs a bit of explaining as this assumes that your drawing units are not set to "Unitless" and the block defnitions are not unitless. If this is the case any unitless blocks will not be processed. Any problems let me know. (defun LM:unique (l) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))) ;; set "by block" to all entities in block definition (defun BB:setByBlock (nam / blc blk) (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq blk (vla-item blc nam)) (vlax-for x blk (if (= "0" (vlax-get-property x 'layer)) (vlax-put-property x 'lineweight acLnWtByBlock))) ) (vl-load-com) (defun c:bf ( / c_doc sel cnt obj col) (setq c_doc (vla-get-activedocument (vlax-get-acad-object))) (princ "\nSelect blocks : ") (setq sel (ssget '((0 . "INSERT")))) (cond (sel (repeat (setq cnt (sslength sel)) (setq obj (vlax-ename->vla-object (ssname sel (setq cnt (1- cnt))))) (cond ( (= :vlax-true (vlax-get-property obj 'isdynamicblock)) (setq col (cons (vla-get-effectivename obj) col) col (cons (vla-get-name obj) col) ) ) (t (setq col (cons (vla-get-effectiveName obx) col))) );end_cond );end_repeat (setq col (LM:unique col)) (foreach x col (BB:setByBlock x)) ) ( (princ "\nNothing Selected")) );end_cond (vla-regen c_doc acActiveViewport) (princ) ) (defun c:lwbb ( / c_doc c_blks) (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) c_blks (vla-get-blocks c_doc) );end_setq (vlax-for blk c_blks (cond ( (and (= :vlax-false (vlax-get-property blk 'isxref)) ;NOT an XREF (= :vlax-false (vlax-get-property blk 'islayout)) ;NOT A LAYOUT (/= 0 (vlax-get-property blk 'units)) ;NOT A DIMENSION );end_and (vlax-for itm blk (if (= "0" (vlax-get-property itm 'layer)) (vlax-put-property itm 'lineweight acLnWtByBlock)) );end_for ) );end_cond );end_for (vla-regen c_doc acAllViewports) (princ) );end_defun Edited November 13, 2019 by dlanorh code update Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 13, 2019 Author Share Posted November 13, 2019 what must i use lm or bf? between codes give me bad argument type Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 13, 2019 Share Posted November 13, 2019 7 hours ago, jim78b said: what must i use lm or bf? between codes give me bad argument type type bf for your corrected original code type lwbb for the second code. This has been updated above as there was a hyphen missing which caused the error. Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 14, 2019 Author Share Posted November 14, 2019 (edited) I NEED THE SELECTION SET BUT GIVE ME ERROR WHY? I only copy BF but don't do anything sorry Edited November 14, 2019 by jim78b Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 14, 2019 Share Posted November 14, 2019 2 hours ago, jim78b said: I NEED THE SELECTION SET BUT GIVE ME ERROR WHY? I only copy BF but don't do anything sorry For bf you need to copy bf lm:unique and bb:setbyblock then type bf to run it. Copy all of the below or download the attached. (defun LM:unique (l) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))) ;; set "by block" to all entities in block definition (defun BB:setByBlock (nam / blc blk) (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq blk (vla-item blc nam)) (vlax-for x blk (if (= "0" (vlax-get-property x 'layer)) (vlax-put-property x 'lineweight acLnWtByBlock))) ) (vl-load-com) (defun c:bf ( / c_doc sel cnt obj col) (setq c_doc (vla-get-activedocument (vlax-get-acad-object))) (princ "\nSelect blocks : ") (setq sel (ssget '((0 . "INSERT")))) (cond (sel (repeat (setq cnt (sslength sel)) (setq obj (vlax-ename->vla-object (ssname sel (setq cnt (1- cnt))))) (cond ( (= :vlax-true (vlax-get-property obj 'isdynamicblock)) (setq col (cons (vla-get-effectivename obj) col) col (cons (vla-get-name obj) col) ) ) (t (setq col (cons (vla-get-effectiveName obx) col))) );end_cond );end_repeat (setq col (LM:unique col)) (foreach x col (BB:setByBlock x)) ) ( (princ "\nNothing Selected")) );end_cond (vla-regen c_doc acActiveViewport) (princ) ) bf.lsp 1 Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 14, 2019 Author Share Posted November 14, 2019 thanks a lot now work! Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 14, 2019 Share Posted November 14, 2019 28 minutes ago, jim78b said: thanks a lot now work! No problem. Sorry for the confusion. Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 14, 2019 Author Share Posted November 14, 2019 Sorry me for a lot of requests. Have a nice day Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 sorry in the lisp i need also that the color on layer 0 is set to byblock is possible to edit ? thanks Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 16, 2019 Share Posted November 16, 2019 updated attached bf.lsp Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 sorry don't work give me bad argument ; error: bad argument type: VLA-OBJECT nil layer 0 color is not set to byblock Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 is there a come like setbylayer with a window to choose every time the options? Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 16, 2019 Share Posted November 16, 2019 Missed that it was in an if statement. Attached amended, minimally tested and working on my system. bf.lsp 1 Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 Thank you so much i test it later .have a nice day Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 (edited) 1 hour ago, dlanorh said: Missed that it was in an if statement. Attached amended, minimally tested and working on my system. bf.lsp 1.28 kB · 1 download don' t work sorry gain i tried to create a block with 2 lines on layer 0 color bylayer and then a center line on layer ex:axis... Edited November 16, 2019 by jim78b Quote Link to comment Share on other sites More sharing options...
jim78b Posted November 16, 2019 Author Share Posted November 16, 2019 this an example new block.dwg Quote Link to comment Share on other sites More sharing options...
