Sye1982 Posted January 29, 2009 Posted January 29, 2009 Afternoon all, Im trying to create a line drawing from a jpeg image as simply super imposing the image onto an existing autocad drawing is not sufficient.. basically i need to create the pattern of finger prints in autocad which i am finding extremmly difficult!! I have tried to attach the image to show you but the file size is to large can anyone help?? Quote
Sye1982 Posted January 29, 2009 Author Posted January 29, 2009 or if anyone knows how i could create a cad drawing of a finger print? Quote
skipsophrenic Posted January 29, 2009 Posted January 29, 2009 have you got a pdf to CAD converter? if so Print jpeg, scan it back in as a pdf, an then convert the pdf to a dwg. Quote
f700es Posted January 29, 2009 Posted January 29, 2009 Can you not insert the raster image and trace over it? Quote
Sye1982 Posted January 29, 2009 Author Posted January 29, 2009 tried tracings its to hard, oultines of a finger print is pretty detailed.. pdf to cad covertor?? where can i get this, can i download it anywhere? thanks Quote
skipsophrenic Posted January 29, 2009 Posted January 29, 2009 Trial Version Here let's you use it 20 times before you have to buy or uninstall: http://www.aidecad.com/ Quote
Sye1982 Posted January 29, 2009 Author Posted January 29, 2009 nice one, thanks alot!! iell give that a try Quote
f700es Posted January 29, 2009 Posted January 29, 2009 If it is a vector PDF e-mail it to me and I'll open in Adobe Illustrator and export to a DWG for you. f700esyahoocom Quote
skipsophrenic Posted January 29, 2009 Posted January 29, 2009 Or Theres That:D Is there anything you can't do f700es, or am I doomed to be a constant learner? LOL Quote
Phiphi Posted February 8, 2009 Posted February 8, 2009 Afternoon all,... I have tried to attach the image to show you but the file size is to large can anyone help?? There is a freeware called FastStone Photo Resizer 2.8 that can be downloaded from http://www.faststone.org/ Quote
f700es Posted February 8, 2009 Posted February 8, 2009 Or Theres That:D Is there anything you can't do f700es, or am I doomed to be a constant learner? LOL Oh, I learn a lot too everyday Thanks for the kind words though. Sean Quote
Sye1982 Posted February 13, 2009 Author Posted February 13, 2009 thanks for everyones help, I used the pdf to cad convertor in the end and that worked out fine for what i needed.. Quote
macareewall Posted March 11, 2009 Posted March 11, 2009 or if anyone knows how i could create a cad drawing of a finger print? You can try this converter next time: http://www.autodwg.com/vectorNow.htm it can trace the raster image and convert to vector lines. Quote
