Drawing Trays - command sequence
Sambuddy
how do I get the first part to work? how do I combine the two?
How do I have it so first pline is drawn/executed, followed by then (c2 command) measure command to insert specific block and then (c3 command) which is offset on both sides and delete original is executed?
as you can see it looks so bad...
please help
(defun c:c2 (/ d1)
(setq d1 (entget (car (entsel))))
  (setq d2 (command "_.measure" "d1" "B" "Tx - Dalle béton + tapis" "Y" "1200" ""))
(vl-load-com)
(defun c:c3 ( / *error* of undo doc ss )
  (defun *error* ( msg )
    (and undo (vla-EndUndomark doc))
        (princ (strcat "\n** Error: " msg " **")))
    (princ))
  (if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
           (setq of (getdist "\nSpecify Offset Distance: ")))
      (setq undo (not (vla-StartUndomark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))))
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
        (mapcar (function (lambda (o) (vl-catch-all-apply (function vla-offset) (list obj o))))
                (list of (- of)))
        (vla-delete obj))
      (setq undo (vla-EndUndoMark doc))))
