REQ : lisp to draw polyline rebar end hook side indecator
Abdulellah
hello .
i am new at this forum
can you help me to write lisp  .
thanks for all worthily efforts
abdulellah.alattab@gmail.com
Edited by Abdulellah
10 minutes ago, Abdulellah said:
hello .
-select polyline
-ask hook side at start point and it is length and angle (preferd 45 degree )
-ask hook side at end point and it is length and angle (preferd 45 degree )
This is a good time to start to learning lisp, without getting to smart about the task you want a extra line either left or right of a pline end.
This would be done using the endpoint and startpoint of a pline, then using the polar command working out a new point adding the line then to the pline.
So a start get the pline vertice points this allows you to work out the pline end segments angles. using polar command draw the new line +45 to the angle ask is it correct direction if not erase and use -45 to the angle.
Ok so some code
(setq plent (entsel "Pick pline"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
; ((156.0 78.0) (307.957959107735 78.0) (307.957959107735 203.997487733392)) ; this is a L pline 3 points
(setq pt1 (nth 0 co-ord)) ; 1st point
(setq pt2 (nth 1 co-ord)) ; second point
(setq x (- (length co-ord) 1)) ; how many points- 1 as 1st point is 0
(setq pt3 (nth (- x 1) co-ord)) ; second last point
(setq pt4 (nth x  co-ord)) ; last point
(setq ang1 (angle pt2 pt1)) ; angle ofthe pline
(setq ang2 (angle pt3 pt4))
(setq add (getreal "Enter distance to add on"))
ok your turn
Pt5 using polar command
then line pt1 pt5
if wrong direction use mirror command note angle must be in radians so use (* 0.75 pi) for 135 degrees.
Please to others have to start at some point.
Complete code to do what you want it is short.
Edited by BIGAL
ok . we can reduce tasks to one task as this order
- enter lisp command in prompt line like hook ( say hok )
- select point which  you want to add hook regardless if at poly line end  or not
Yes there are more things to do with this code but I would like this to be a learning example, getint is the next step or see image below.
see last post
More advanced next step.
image.png.e1ff5714a3b1e35014857152c8f3c5db.pngimage.png.422d9d9d3bfa8180e211091c291ef5b3.png
Edited by BIGAL
(defun c:plhook ( / plent pt1 pt2 pt3 x pt5 add ang1 ang2)
(setq pt2 (nth 1 co-ord) ; second point
(setq pt5 (polar pt1 (+ (* 0.75 pi)) add)) ; 135 degrees
(command "line" pt1 pt5 "") ; new line
(setq ans (getstring "is line ok Y or N")) ; is it in correct direction
(if (= "Y" (strcase ans)) ; y or Y
(princ "ok")
(command "mirror" "Last" "" pt1 pt2 "Y") ; flip line
(setq pt5 (polar pt4 (+ (* 0.75 pi)) add)) ; other end
(command "line" pt4 pt5 "")
(princ "ok")
(c:plhook)
Re doing was typo in code.
(while (setq plent (entsel "Pick pline Enter to exit"))
(setq pt5 (polar pt1 (+ (* 0.25 pi) ang1) add)) ; 135 degrees
    (princ "ok")
(setq pt5 (polar pt4 (+ (* 0.25 pi) ang2) add)) ; other end
    (princ "ok")
    (command "mirror" "Last" "" pt4 pt3 "Y")
(c:plhook)
Edited by BIGAL
  • Thanks 1
    (princ "ok")
    (princ "ok")
(c:plhook)
greate job herro , very usefull lisp , one more  thing for maximum benifit , can you do that with *. dcl window at right select hook side at start point , at left select hook side at end point .
after add hooks , can join both hooks to be with polyline as one object .
then select new connected polyline and fillet all poly segment together with predefined redius.
i am have confident to do that .
Multi GETVALS.lspTry this
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(if (/= plent nil)
(setq ans (AH:getvalsm (list "Enter length" "Hook length " 5 4 "30" "Radius" 5 4 "25" )))
(setq add (atof (nth 0 ans)))
(setq rad (atof (nth 1 ans)))
(setq ans (ah:butts but "V" '("Flip  " "Yes" "No")))
(if (= "No"  ans)
    (princ "ok")
(command "pedit" (car plent) "join" (entlast) "" "")
(if (= "No"  ans)
    (princ "ok")
(command "fillet" "Polyline" "r" rad  (car plent))
(c:plhook)
Multi radio buttons.lsp
Edited by BIGAL
  • Thanks 1
Very embarrassing, for your extra generosity, really you are a wonderful human
    (princ "ok")
    (princ "ok")
(c:plhook)
You need to save the two files in a Autocad supported path or edit the "Load path.
(if (not AH:Butts)(load "c:\\myprograms\\lisps\\Multi Radio buttons.lsp"))
(if (not AH:Butts)(load "c:\\put your path here\\Multi Radio buttons.lsp"))
  • Thanks 1
  • 2 weeks later...
    (princ "ok")
    (princ "ok")
(c:plhook)
mr.begal , some thing error  with this code , try to long multi segment poly , measure  angle , delete end lines , try it agine  please , belive me some thing error happen , can you refine it
This is latest has offset radius and angle pick pline anywhere.
(defun c:plhook ( / plent pt1 pt2 pt3 pt4 ang3 pt5 add ang1 ang2 ang3)
(setq ans (AH:getvalsm (list "Enter length" "Hook length " 5 4 "30" "Radius" 5 4 "25" "angle " 5 4 "45")))
(setq ang3 (* pi (/ (atof (nth 2 ans)) 180.0)))
(setq pt5 (polar pt1 (+ ang3 ang1) add)) ; 135 degrees
(if (= "No"  ans)
    (princ "ok")
(setq pt5 (polar pt4 (+ ang3 ang2) add)) ; other end
(if (= "No"  ans)
    (princ "ok")
(c:plhook)
  • Thanks 1
So 30 years of command calls and they still work !  I have a new I7 laptop just did 2000 iterations on another post in less than 2 seconds using command calls. I started in the days of a 8 bit machine, mono screen if you counted to ten that was a good day to do one sort of simple coding. Were splitting micro seconds now between command, VL- and entmake doing a (command "line" pt1 pt2 "") is how many micro seconds v's entamake. Doing 20,000 yes need to look at speed.
Yes probably worth adding a osmode 0 to code. But as its rebar it has a reasonable length for extensions so snap end is not a problem. Unless you zoomed a long way out.
Edited by BIGAL
