Block definition - Random
sketch11
Relating to block definition, using command BLOCK, is there a setting such that AutoCAD randomly generates block names.
Similar to the definition generated by "Paste as Block".
When you use the command BLOCK, Autocad expects you to specify a name. I don't know of any way to tell Autocad to assign a random name on its own. If you want to create blocks with random names, the easiest way would be to select a group of objects, Ctrl+C to copy and then Paste as Block, as you mentioned.
