Creating a Plan View Pipe Mask for Fittings
Silvercloak
Hi,
    One problem I've having is getting my fittings to appear when the drawing is plotted.  I can't get convertlineworktomaskblock to mask any plan view pipes.  Nor does wipeout seem to help me.  I've created a Valve style and tried to use part mask to mask the pipe out.  Right now I'm getting this;
When what I actually want is more like this;
I really do NOT want to go back to just using polylines and blocks.  Please tell me there's a solution to this.
Silvercloak
That's the first thing I tried.  It hasn't made a difference.  I'm absolutely baffled as to why this isn't working.  I know it CAN work because I had Null structures that were breaking the pipe previously that I used to turn off when I didn't need to see them.  Now even they aren't breaking the pipe with part mask.  I'm completely baffled as to what changed to make this pipe seemingly indestructible. :P
Silvercloak
10 hours ago, steven-g said:
Cany you post an example file, so we can see what is going on.
Here's an example file.  I've tried to limit what I show and stripped the file down so I don't post anything proprietary from my company.  However this should suffice to show what I'm dealing with right now.
Thanks Steven,
Silvercloak
Pipe Example.dwg
Separate wipeout, the valve is a Aecc object I haven't used so if a block maybe check wipeout draw order.
I bedited PWBEGV and added a wipeout, then draw order to back, save new block, seems to have worked.
