samifox
fieild reading block ucs rather that world ucs
samifox
hi
i have created a block with a field that should measure the Y level, but i realize that the field reading the internal block Y position rather than the world Y position. is there a way to measure the world UCS instead the block one?
Share this post
Link to post
steven-g
If you use an attribute, and place your field in the default value, then when you select an object that you use to get the 'Y' coordinate from (I presume that is how you are getting 'Y'
Then an extra tick box is available in the field dialogue 'Display value for block reference'. This will let the field read the value relative to the world. This option isn't available with just a standard field.
Share this post
Link to post
samifox
 how did i miss...thanks my dear cadder
Share this post
Link to post
samifox
i dont have this feature . using ACA 2019...how come?
Share this post
Link to post
BIGAL
Civ3D 2020 maybe.
Share this post
Link to post
steven-g
Are you inside the block editor?
Share this post
Link to post
