Brita Posted February 10, 2020 Share Posted February 10, 2020 (edited) Hi, I recently installed 3ds Max 2020 and I cant find the Graphite/ Polygon Modeling tab on the ribbon. I have tried reverting to startup layout and turning the ribbon on an off. I also have editable poly object selected, but still the tools does not show up. I've tried seraching in max help and customize the ribbon without any luck. It is probably a really stupid small setting somewhere, but I cant find it. Anyone had same problem? Or have a solution? The only available tabs on my ribbon is : Get Started, Object Inspection, Basic Modeling, Materials, Object Placement, Populate, View and Lighting and Rendering I have also googled for days without getting any wiser, please help Thanx, Brita Edited February 10, 2020 by Brita Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 10, 2020 Share Posted February 10, 2020 I haven't used 3ds max in years, but what happens if you right click up in the ribbon area, where you drew that question mark? Do you get any options for hiding or showing panels? Quote Link to comment Share on other sites More sharing options...
eguitler Posted May 6, 2020 Share Posted May 6, 2020 Hi there! Some one have an answer? I am looking for the freeform bar, but I can't find it in 3ds Max 2020. Quote Link to comment Share on other sites More sharing options...
eguitler Posted May 7, 2020 Share Posted May 7, 2020 I leave you the solution: At the ribbon tab press Right click > Ribbon configuration > Reset ribbon to default. Automatically, the Freeform will show up in the tootlbar. Quote Link to comment Share on other sites More sharing options...
