Sign in to follow this
pmadhwal7
Nedd help Rectangle Dimension With area
pmadhwal7
Hi to all is their any lsp which will place dimension on its length and width and also place area of rectangle for more see the attachment
recangle.dwg
Share this post
Link to post
BIGAL
Here is a start I will let you add the area use (entlast) of the rectang and you can get the property Area and add.
; simple draw a box and dimension it
; By Alan H March 2019
' info@alanh.com.au
(defun ah:box ( / pt1 pt2 pt3 ahl ahh ahoff )
(setq oldsnap (getvar 'osmode))
(setq oldang (getvar 'angdir))
(setq pt1 (getpoint "\nPick lower left"))
(setvar 'osmode 0)
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Simple rectang" "Enter length" 8 7 "1" "Enter height " 8 7 "2")))
(setq ahL (atof (nth 0 ans)))
(setq ahH (atof (nth 1 ans)))
(setq pt2 (polar pt1 0.0 ahl))
(setq pt3 (polar pt2 (/ pi 2.0) ahH))
(command "rectang" pt1 pt3)
(setq ahoff (* 2.0 (* (getvar 'dimasz)(getvar 'dimscale)))) ; change offset as required
(setq pt4 (polar pt2  (* pi 1.5) ahoff))
(command "dim" "hor" pt1 pt2 pt4 "" "exit")
(setq pt4 (polar pt3 0.0 ahoff))
(command "dim" "Ver" pt2 pt3 pt4 "" "exit")
(setvar 'osmode oldsnap)
(ah:box)
Multi GETVALS.lsp
Share this post
Link to post
pmadhwal7
' info@alanh.com.au
(setvar 'osmode 0)
(ah:box)
HOW TO USE MULTI GETVALS???
Share this post
Link to post
BIGAL
Save the box.lsp and multi getvals to a location in your support paths, somewhere where you save your free stuff.
The multi getvals is a Library routine that creates DCL on the fly rather than line by line questions, in this case its called by this line. There are examples in the code if you look, you can change default values the "1" & "2"
Edited by BIGAL
Share this post
Link to post
pmadhwal7
this the perfect lsp from lee mac just one thing not their that Area text is it possible to place Area text before total value.
http://www.lee-mac.com/areastofield.html
Edited by pmadhwal7
Share this post
Link to post
