Sign in to follow this
Aarya
Renaming layout tags
Aarya
Hi,
hope you all are doing good.
I have a drawing with 20 to 30 layouts into it and they keep on adding. So I have to rename them one by one like 1 of 30 or 1 of 31 . Is there any shortcut to do this fast.
thanks in advance
Share this post
Link to post
BIGAL
You can rename layouts, change their order, delete, insert, etc.
Now the questions, do you have a title block and does it have attributes so say you get a layout called D01 and the sheet number is  01 of 25. Yes I have code so do others.
Have you used sheet sets ?
Need a sample dwg with title blocks and a couple of layouts.
Share this post
Link to post
