XREF in MODEL SPACE
CAD_Noob
How can we determine in lisp if an xref is in model space or paper space?
Anybody has a code that detaches all xref in model space but retain the xref that are in paper space?
You could try this oldie
(defun c:detachx ( / *error* c_doc c_blks b_str ss cnt obj)
  (defun *error* ( msg )
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred.")))
  );_end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_blks (vla-get-blocks c_doc)
  );end_setq
  (vlax-for blk c_blks
    (if (= :vlax-true (vlax-get-property blk 'isxref)) (setq b_str (strcat b_str "," vlax-get-property blk 'name)))
  );end_for
  (setq b_str (vl-string-trim "," b_str)
        ss (ssget "_X" (list '(0 . "INSERT") '(410 . "Model") (cons 2 b_str)))
  );end_setq
  (cond (ss
          (repeat (setq cnt (sslength ss))
            (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))))
            (vla-detach obj)
          );end_repeat
  );end_cond
);end_defun
There are no checks for locked layers, so ensure all relevant layers are unlocked. I would also test it on a copy of a drawing first.
What if the same xref resides in model and paperspace?
 I don't have such case. Xref in Paperspace is commonly Titleblocks and legends only.
  );end_setq
  );end_for
  );end_setq
  (cond (ss
            (vla-detach obj)
          );end_repeat
  );end_cond
);end_defun
i got this error :
Quote
Command: DETACHX
An Error : bad argument type: stringp nil occurred.
Command:
b_str needs a check like so:
(if (and (setq b_str (vl-string-trim "," b_str))
	   (setq ss (ssget "_X" (list '(0 . "INSERT") '(410 . "Model") (cons 2 b_str))))
      )					;end_setq
      (vla-detach obj)
    )					;end_repeat
      )					;end_setq
      (vla-detach obj)
    )					;end_repeat
  );end_setq
  );end_for
      )                    ;end_setq
      (vla-detach obj)
    )                    ;end_repeat
  (cond (ss
            (vla-detach obj)
          );end_repeat
  );end_cond
);end_defun
I incorporated this with @dlanorh lisp and i got this error
Quote
Command: DETACHX
Command:
This too:
    (setq b_str (strcat (if b_str b_str "") "," vlax-get-property blk 'name))
)					;end_for
@dlanorh can take care of any other issues that arise 😉
Edited by ronjonp
  );end_setq
  );end_for
      )                    ;end_setq
      (vla-detach obj)
    )                    ;end_repeat
  (cond (ss
            (vla-detach obj)
          );end_repeat
  );end_cond
);end_defun
Sorry, lots of problems on my work computer, my antivirus is being overenthusiastic, and intermittantly thinks the mouse driver is malware. Trying to cut and paste code is a problem right now so I've attached an updated lisp that addresses the problems.
detachx.lsp
i still get the same error :(
