Jonathan Handojo Posted April 2, 2020 Share Posted April 2, 2020 Hi guys, Can someone explain the result behind (eq '(1 2) '(1 2))? I've been using the eq function quite a while and just found this out. I can very well use equal, but this just rings a concern. Thanks, Jonathan Handojo Quote Link to comment Share on other sites More sharing options...
Anushka Posted April 2, 2020 Share Posted April 2, 2020 (equal '(1 2) '( 1 2)) like this ?? Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 2, 2020 Share Posted April 2, 2020 This will give you a hint (setq a '(1 2) b a) (eq a b) => T Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted April 2, 2020 Author Share Posted April 2, 2020 4 minutes ago, dlanorh said: This will give you a hint (setq a '(1 2) b a) (eq a b) => T Man that's weird... I mean normally if you want to compare between two lists, they are in most cases not gonna be in that form. You normally have a list coming from one evaluation, and another list that evaluates to the exact same list (in my case, it's a list of strings) from another evaluation. Then when I run (eq a b), it evaluates to nil Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 2, 2020 Share Posted April 2, 2020 (edited) basically with lists (eq ...) tests if they are bound to the same object/entity. Same applies to (= ..). However (equal ...) tests if they evaluate to the same thing. Edited April 2, 2020 by dlanorh Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 2, 2020 Share Posted April 2, 2020 (edited) 7 hours ago, Jonathan Handojo said: Man that's weird... I mean normally if you want to compare between two lists, they are in most cases not gonna be in that form. You normally have a list coming from one evaluation, and another list that evaluates to the exact same list (in my case, it's a list of strings) from another evaluation. Then when I run (eq a b), it evaluates to nil be careful (setq a '(1 2) b a c a) (eq a '(1 2) ) ;nil (eq a b) ;T (equal '(1 2) a ) ;T (= '(1 2) a b) ;nil (= a b c) ;T Edited April 2, 2020 by hanhphuc Jon's dizziness so '(1 2 3) -> '(1 2) 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted April 2, 2020 Author Share Posted April 2, 2020 2 hours ago, dlanorh said: basically with lists (eq ...) tests if they are bound to the same object/entity. Same applies to (= ..). However (equal ...) tests if they evaluate to the same thing. Makes sense now, although (eq 2 2) or (eq "str" "str") returns T. 2 hours ago, hanhphuc said: be careful (setq a '(1 2 3) b a c a) (eq a '(1 2 3) ) ;nil (eq a b) ;T (equal '(1 2 3) a ) ;T (= '(1 2 3) a b) ;nil (= a b c) ;T Oh, please don't make me any dizzier than I already am 1 Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 2, 2020 Share Posted April 2, 2020 Just now, Jonathan Handojo said: Makes sense now, although (eq 2 2) or (eq "str" "str") returns T. I know, but 2, "str" and any real numbers are not lists and so are evaluated. 1 Quote Link to comment Share on other sites More sharing options...
myloveflyer Posted April 3, 2020 Share Posted April 3, 2020 (eq expression 1 expression 2) It mainly determines whether the two expressions have the same constraint conditions (whether Expression 1 and Expression 2 are set to the same object. (setq f1 '(a b c) f2 '(a b c)) (setq f3 f2) (eq f1 f2) ;---->nil ,Because f1 and f2 have the same value, they do not point to the same list (eq f3 f2) ;---->T,Because f3 and f2 point to the same list So I will tell you this, you should be able to understand it. In the case of not sure whether it is the same table, I generally use (equal expression 1 expression 2 [FUZZ]) 1 Quote Link to comment Share on other sites More sharing options...
