RetroCAD Posted May 16, 2020 Share Posted May 16, 2020 January 16, 1992 AutoCAD for Windows Questions and Answers 1. What is AutoCAD for Windows? AutoCAD for Windows is a Windows-specific version of AutoCAD Release 11. It provides a Windows-standard interface which makes CAD easy to learn and use even for the novice. From the easily customizable tool bar to its informative on-line hypertext Help, AutoCAD for Windows proves that powerful CAD software doesn't have to be awkward or difficult. In addition to interface improvements in AutoCAD itself, the open architecture of AutoCAD for Windows allows third-party Developers to construct powerful applications quickly, linking the power of AutoCAD with other Windows applications like spreadsheets and databases. With the Autodesk Development System (ADS), Developers will be able to create an exciting new class of tightly integrated applications. Using its Windows clipboard support, AutoCAD drawings can be placed directly into documents and other files in word- processing, desktop publishing, or presentation graphics programs. Finally, Dynamic Data Exchange (DDE) links to Windows spreadsheets and other programs allow the customer to conduct experimental, interactive "what-if" queries on design changes to his AutoCAD drawing, giving him the flexibility of parametric design control. 2. Who should use AutoCAD for Windows? Anyone who needs the design, drafting, drawing, and modeling tools of AutoCAD, and who wants to access them through a Windows interface. This includes all present AutoCAD customers, as well as those who have been waiting for a Windows version of AutoCAD, or who were seeking a more streamlined interface to help them become proficient with AutoCAD more quickly. We believe AutoCAD for Windows opens up new markets and makes CAD accessible to new customers. 3. What are some of AutoCAD for Windows' key features? a) Full AutoCAD Release 11 feature set b) Interface 1) Windows-standard Graphical User Interface (GUI) 2) Operates as a well-behaved multi-tasking Windows application 3) Bitmap menus and hierarchical menus 4) Tool Bar 5) Context-sensitive Help with hypertext links 6) Complete reference manual available on-line c) Connectivity 1) Support of clipboard metafile and bitmap formats 2) Dynamic Data Exchange links 3) Open architecture, user programmable and customizable DDE 4. What are the hardware requirements for AutoCAD for Windows? AutoCAD for Windows requires an 80386- or 80486-based PC- compatible computer with at least 4MB of RAM, 20MB free hard disk space, an 80287 or 80387 math coprocessor chip, a mouse, a VGA-or-better video adapter and monitor supported by Windows, DOS 3.3 or higher, and Windows 3.0 running in Enhanced mode. 5. What is the packaging? AutoCAD for Windows consists of 8 diskettes and an Installation Guide. 6. What does it do that AutoCAD Release 11 386 does not do? AutoCAD for Windows has three areas of functionality not presently included in AutoCAD Release 11 386: 1) Access to the Windows clipboard -- This allows AutoCAD for Windows customers to copy an object to the clipboard in either vector format, in which case it becomes a Windows metafile (WMF), or in raster format, in which case it becomes a Windows bit map (BMP). From there, the customer can then paste the image into another Windows application, such as a word-processing, desktop-publishing, or presentation graphics program. 2) Dynamic Data Exchange -- As a default, AutoCAD for Windows supports Windows Dynamic Data Exchange links between an external data source and the AutoCAD drawing database. For example, when the customer changes attributes in a Microsoft Excel sprea dsheet, those attributes can be instantly updated in the AutoCAD for Windows drawing. Because AutoCAD's DDE support is open and programmable, the customer can also create his own customized DDE connections by using a programming language like C. This allows him to create a DDE application that instantly updates the dimensions of objects in the AutoCAD drawing when data is changed in a Windows database program. Or a Bill of Materials can be updated automatically in a Windows spreadsheet when the AutoCAD drawing is edited. 3) Windows interface -- Because AutoCAD for Windows complies with Windows standards on menus and dialogues, it is much easier for the Windows customer who has never previously used AutoCAD to learn the program. The pull-down menus and dialogues also make AutoCAD for Windows easier to use for production work. 7. What doesn't it have or do that AutoCAD Release 11 386 has? There are two features or areas of functionality in AutoCAD Release 11 386 that are not supported in this first release of AutoCAD for Windows: 1) Advanced Modeling Extension (AME) -- AME will not work with AutoCAD for Windows because of Windows' memory architecture. Since AME is a 32-bit application and Windows is a 16-bit operating system (for now), we were not able to make AME work with AutoCAD for Windows in this initial release. 2) Server Authorization -- This first release of AutoCAD for Windows does not support AutoCAD Release 11 386's concurrent use network license feature. 8. How does its performance compare to AutoCAD Release 11 386? Our own internal performance benchmarks show AutoCAD for Windows to be one-half to one-third as fast as AutoCAD Release 11 386. However, these benchmarks are designed to test the flat-out raw speed of the programs, and do not reflect the typical work flow of many AutoCAD customers. We believe that AutoCAD for Windows' performance will be very acceptable for most customers on all but the largest and most complex drawings. The productivity gains from the easy-to- use Windows interface and Windows' ability to run more than one program concurrently mean that this version of AutoCAD can actually be faster to use for many design projects. 9. Will my AutoLISP scripts run with AutoCAD for Windows? Yes. 10. Will my ADS applications run with AutoCAD for Windows? All ADS applications will need to be recompiled and some also may require modification. You should contact your ADS Developer and ask for an updated ADS application that is compatible with AutoCAD for Windows. 11. Will my present ADI driver work with AutoCAD for Windows? No. You should contact your ADI Developer and ask for an updated ADI driver for AutoCAD for Windows. 12. Can I run multiple instances of AutoCAD for Windows, or open multiple drawings? No. Windows only allows a single instance of AutoCAD for Windows because it is a large memory model application. Also, the first release of AutoCAD for Windows does not support the Multiple Document Interface. 13. Why do you call it the AutoCAD for Windows "Extension"? Because the program code provided to a current AutoCAD customer in this package requires that the user have an AutoCAD Release 11 license for the system on which he will install this Windows program. The name is consistent with the AutoCAD Advanced Modeling Extension. It also means the customer has the choice of switching between AutoCAD Release 11 386 and AutoCAD for Windows on the same system. We consider the AutoCAD for Windows Extension a dual use license. Quote Link to comment Share on other sites More sharing options...
