BricsCAD123 Posted July 15, 2020 Posted July 15, 2020 (edited) I have taken a .lsp from http://www.lee-mac.com/index.html and I want to alter it slightly so that the xref can be assigned to a specific layer "z_xref" rather than having it on layer " 0" I have written the command below however i'm unsure where to put it in the lisp (also included below) (command "-layer" "s" "z_xref" "exit" "") (defun c:RlxPsXref (/ _getfolder RLXref_SetPathType app adoc odbs odbx v xref folder dwg xr lay) (vl-load-com) (defun _getfolder ( m / sh f r ) (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application") f (vlax-invoke-method sh 'browseforfolder 0 m 0)) (vlax-release-object sh)(if f (progn (setq r (vlax-get-property (vlax-get-property f 'self) 'path))(if (wcmatch r "*\\") r (strcat r "\\"))))) ; i is 0 (absolute), 1 (relative) of 2 (no) -xref path (defun RLXref_SetPathType (i) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XattachDialog") "PathType" i)) (setq odbs "ObjectDBX.AxDbDocument" v (substr (getvar 'acadver) 1 2) adoc (vla-get-activedocument (setq app (vlax-get-acad-object)))) (RLXref_SetPathType 1) (cond ((vl-catch-all-error-p (setq odbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (atoi v) 16) odbs (strcat odbs "." v)))))) (princ "\nObject DBX interface not created!")) ((not (setq xref (getfiled "Select Xref to attach" "" "dwg" 0))) (alert "No Xref was selected")) ((setq folder (_getfolder "Select folder with drawings to attach xref to")) (foreach dwg (vl-directory-files folder "*.dwg" 0) (setq dwg (strcat folder dwg)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list odbx dwg))) (princ (strcase (strcat "\nError opening: " dwg))) (progn (princ (strcat "\nOpening: " dwg)) ; attach xref (if (vl-catch-all-error-p (setq xr (vl-catch-all-apply 'vla-AttachExternalReference (list (vla-get-ModelSpace odbx) xref (vl-filename-base xref) (vlax-3d-point 0 0 0) 1 1 1 0 :vlax-false)))) (princ (vl-catch-all-error-message xr)) (progn (vlax-for lay (vla-get-layouts odbx) (if (/= "MODEL" (strcase (vla-get-name lay))) (vlax-invoke odbx 'copyobjects (list xr) (vla-get-block lay)))) (vla-delete xr) ) ) ; save drawing (vla-saveas odbx (vla-get-name odbx)) ) ) ) ) ) (princ) ) Edited July 15, 2020 by SLW210 Added Code Tags Quote
BIGAL Posted July 16, 2020 Posted July 16, 2020 Try here use make as it will make the layer if not exist and set to current. Not tested. ; attach xref (command "-layer" "m" "z_xref" "") Quote
BricsCAD123 Posted July 16, 2020 Author Posted July 16, 2020 1 hour ago, BIGAL said: Try here use make as it will make the layer if not exist and set to current. Not tested. ; attach xref (command "-layer" "m" "z_xref" "") The xref's are still being assigned to layer "0" Attach XR to dwg's PS Ammended.lsp Quote
