oturk1
HI,
I need to create a Lisp to do the following in a series of drawings within a folder and then save as a new file.
Superflatten entire drawing.
Audit and fix errors.
overkill entire drawing
Convert all.
Purge all.
Remove Hatching.
Remove DIms.
Create boundary box from most southern and most western extremities of building.
move boundary box and content from basepoint to be 2000,2000 from 0,0.
Id like to type "deepclean" as command in future,
I have over 1000 drawings to run this on so ideally id like to find a routine which will automatically do this to all files within a folder, without the need to manually open each one?
Edited by oturk1
added tags
If you look at my question just before yours, there is a Lisp in there to run a script in the core console - which will sort out the batch processing, you just need to work out the script to do your stuff.
Lee Mac has a script writer on his website which is probably easier.
2 hours ago, oturk1 said:
HI,
Convert all.
Purge all.
Remove Hatching.
Remove DIms.
What does "Convert All" mean?
convert command, its something we do to our plans which convert all splines to a particular type of PL. the system we integrate with CAD cant handle splines so is something we need to do to every plan.
Lee Mac routines are superb, ill take a look for the batch processing part.
the part i struggle with is writing the language in Lisp to get the plans cleaned up.
if any help, i already have a code which deletes hatching and dims etc - see below:
(defun c:cleanup (/ ss)
(if (setq ss (ssget "_X" '((0 . "DIMENSION,HATCH,ATTDEF,SOLID"))))
  (command "_.erase" ss "")
(vl-load-com)
 (or doc
     (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (vlax-for b
             (vla-get-blocks
               doc
   (if
     (and
       (eq :vlax-false (vla-get-isLayout b))
       (eq :vlax-false (vla-get-isXref b))
      (vlax-for o b
        (if (eq "AcDbHatch" (vla-get-objectname o))
          (vl-catch-all-apply 'vla-delete (list o))
 (vla-regen doc acAllViewports)
You could try this as a very quick and probably not efficient way.
it will have a dialogue box on the overkill command, but I am not sure how you would do that without it
(defun c:deepclean()
  (command "audit" "Y")
  (command "overkill"(ssget "_X") "")
  (command "convert" "" "")
  (command "PURGE" "A" "*" "N")
  (command "PURGE" "A" "*" "N") ;;twice to capture everything, once more for luck
  (c:cleanup)
  (command "rectang" (getvar "extmin") (getvar "extmax"))
  (command "move" (entlast) "" (getvar "extmin") "2000,2000")
  (command "PURGE" "A" "*" "N") ;;and why not?
Normally someone better comes along and does something weird that works better soon
  (c:cleanup)
The first part of this is great.
the plans we are given are also a mess (see attached in previous post). if you switch to ISO SW View you'll see it was once a 3d dwg. thankfully the objects and faces are gone, so am left with a lot if lines. i need to flatten these so that it is a pure flat drawing which is 0 on the Z axis.
I tried to add flatten command to the above but its throwing a few issues with selecting all and not removing hidden lines - any ideas?
Also the second half of that worked slightly - however, ideally id like to be able to find the extremities of the drawing, rectangle that and then move that along with the entire drawing to 2000,2000.
Apologies if this sounds a bit all over the place.
You could use THIS to flatten the drawing.
OK. I think I understand the second part,
Replace the move line with this one
(command "move" (ssget "_X") "" (getvar "extmin") "2000,2000")
C:cleanup will not run in aeccoreconsole has VL, but if you write a plain script it will but will use open each dwg. This can still be quick, spare pc or start a 2nd session.
Edited by BIGAL
Overkill doesn't work in Core Console either
But I found this which appears to delete duplicated lines. I had to rename the function dxf and to use the ;defun c:clear rather than the one without the ';' to get it to work - not tried it in core console yet though
Way to many options with the overkill command that are saved in the Windows registry. They can be modified and reset as in this example:
;| PLJOIN.LSP 2015 Version
 Joins lines, arcs and polylines then resets overkill defaults & combines co-linear polyline segments.
 If only one object is selected it joins to all connected objects.
 If multiple objects are selected it joins & combines co-linear polyline segments just those objects.
 By Tom Beauford
 BeaufordT@LeonCountyFL.gov
 Macro   ^P(or C:pljoin (load "pljoin.lsp"));pljoin |;
(defun c:pljoin (/ cmdecho peditaccept ss registry CombineEndToEnd CombinePartialOverlaps Ignore IgnorePolylineWidths MaintainAssociativities MaintainPolylines OptimizePolylines Tolerance)
  (princ "\nSelect object to join: ")
  (setq cmdecho (getvar "cmdecho")
        peditaccept (getvar "peditaccept")
        ss (ssget '((0 . "ARC,*LINE")))
        registry (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\Overkill")
  (setvar "cmdecho" 0)
  (setvar "peditaccept" 1)
  (if ss
	(command ".UNDO" "BEgin")
	(princ "CombineEndToEnd = ")(princ (vl-registry-read registry "CombineEndToEnd"))
	(setq
	  CombineEndToEnd (vl-registry-read registry "CombineEndToEnd")
	  CombinePartialOverlaps (vl-registry-read registry "CombinePartialOverlaps")
	  Ignore (vl-registry-read registry "Ignore")
	  IgnorePolylineWidths (vl-registry-read registry "IgnorePolylineWidths")
	  MaintainAssociativities (vl-registry-read registry "MaintainAssociativities")
	  MaintainPolylines (vl-registry-read registry "MaintainPolylines")
	  OptimizePolylines (vl-registry-read registry "OptimizePolylines")
	  Tolerance (vl-registry-read registry "Tolerance")
	(princ "\nCombineEndToEnd = ")(princ CombineEndToEnd)
	(vl-registry-write registry "CombineEndToEnd" "1")
	(vl-registry-write registry "CombinePartialOverlaps" "1")
	(vl-registry-write registry "Ignore" "0")
	(vl-registry-write registry "IgnorePolylineWidths" "0")
	(vl-registry-write registry "MaintainAssociativities" "1")
	(vl-registry-write registry "MaintainPolylines" "0")
	(vl-registry-write registry "OptimizePolylines" "1")
	(vl-registry-write registry "Tolerance" "0.000001")
	(if (= (sslength ss) 1)
          (command "_.pedit" ss "_J" "_all" "" "" "-overkill" ss "" "")
;          (command "_.pedit" ss "_J" "_all" "" "" "-overkill" "L" "" "")
          (command "_.pedit" "_M" ss "" "_J" "_J" "_E" "0.0" "" "-overkill" "L" "" "")
;|	(vl-registry-write registry "CombineEndToEnd" CombineEndToEnd)
	(vl-registry-write registry "CombinePartialOverlaps" CombinePartialOverlaps)
	(vl-registry-write registry "Ignore" Ignore)
	(vl-registry-write registry "IgnorePolylineWidths" IgnorePolylineWidths)
	(vl-registry-write registry "MaintainAssociativities" MaintainAssociativities)
	(vl-registry-write registry "MaintainPolylines" MaintainPolylines)
	(vl-registry-write registry "OptimizePolylines" OptimizePolylines)
	(vl-registry-write registry "Tolerance" Tolerance) |;
      (command "._UNDO" "_End")
  (setvar "cmdecho" cmdecho)
  (setvar "peditaccept" peditaccept)
Thanks for all the replies.
I have discussed the overkill and have agreed its unnecessary and may cause more issues than it fixes.
I've tried to add the flatten all command to the lisp but it says unknown command
"Flatten" "all" "N"
Why would it fail in lisp?
Also you all talk about core console - I've never heard of this before, can anyone enlighten me please?
Google Aeccoreconsole it is Autocad running with no user input but carry out amendments to multiple dwg's.
It can be ran from the winodws CMD line as a batch file
c:\Program files\Autodesk\Autocad 2020\accoreconsole.exe /i d:\alan\test1.dwg /s d:\alan\lisp\test.scr
c:\Program files\Autodesk\Autocad 2020\accoreconsole.exe /i d:\alan\test2.dwg /s d:\alan\lisp\test.scr
c:\Program files\Autodesk\Autocad 2020\accoreconsole.exe /i d:\alan\test3.dwg /s d:\alan\lisp\test.scr
Or auto process a series of dwgs in a folder.
https://through-the-interface.typepad.com/through_the_interface/2012/02/the-autocad-2013-core-console.html
Edited by BIGAL
