Hello every body
how can i get to vertexes of 3dpoly?
(setq en (entget (car (entsel))))
It doesn't provide any vertex.
Thanks all.
Two methods other than diving deeper using  (entnext)
1. Using vlax-curve functions
(setq ent (car (entsel))
      ep (vlax-curve-getendparam ent)
(while (not (minusp ep))
  (setq vlst (cons (vlax-curve-getpointatparam ent ep) vlst)
        ep (1- ep)
);end_while
2. Using a grouping function and activex
(defun group3 (lst / x)
  (repeat 3 (and lst (setq x (cons (car lst) x))) (setq lst (cdr lst)) x)
  (if lst (cons (reverse x) (group3 lst)) (list (reverse x)))
(setq obj (vlax-ename->vla-object (car (entsel)))
      vlst (group3 (vlax-get obj 'coordinates))
        ep (1- ep)
);end_while
Thank you very very much.
This is my version look at object type and use correct 2 or 3.
; pline co-ords example
; By Alan H
(defun getcoords (ent)
  (vlax-safearray->list
    (vlax-variant-value
      (vlax-get-property
    (vlax-ename->vla-object ent)
    "Coordinates"
; convert now to xyz
(defun co-ords2xy (xyz / )
(setq co-ordsxy '())
(if (= xyz 2)
(setq I 0)
(repeat (/ (length co-ords) 2)
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
(if (= xyz 3)
(setq I 0)
(repeat (/ (length co-ords) 3)
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
(setq I (+ I 3))
(setq obj (vlax-ename->vla-object (car  (entsel "Pick obj"))))
(setq co-ords (vlax-get obj 'coordinates))
(cond
(( = (vla-get-objectname obj) "AcDb2dPolyline")(co-ords2xy 2))
(( = (vla-get-objectname obj) "AcDb3dPolyline")(co-ords2xy 3))
(princ co-ordsxy)
To provide a Vanilla AutoLISP solution: the vertices of a 3D polyline are represented using VERTEX subentities which follow the POLYLINE entity - you can access such subentities using the entnext function, e.g.:
(defun c:test ( / e l v x )
    (if (setq e (car (entsel "\nSelect 3D polyline: ")))
        (if (and (= "POLYLINE" (cdr (assoc 0 (setq x (entget e)))))
                 (= 8 (logand 8 (cdr (assoc 70 x))))
                (setq v (entnext e)
                      x (entget  v)
                (while (= "VERTEX" (cdr (assoc 0 x)))
                    (setq l (cons (cdr (assoc 10 x)) l)
                          v (entnext v)
                          x (entget  v)
                (print (reverse l))
            (princ "\nThe selected object is not a 3D polyline.")
Is the 8 check really necessary as if removed still get vertices but with XYZ compared to say get-coordinates  XY for 2d XYZ for 3d. May use this method in future. Using Bricscad.
 2D polyline:
((214.0 52.0 0.0) (157.408781350765 164.576347301707 0.0) (284.086155652032 244.905936122619 0.0) (347.378011556397 199.31930457146 0.0))
3D polyline:
((348.0 42.0 0.0) (302.0 149.0 10.0) (436.0 170.0 15.0) (482.737423332648 107.229403773346 0.0))
; By Alan H
    (vlax-variant-value
      (vlax-get-property
    "Coordinates"
(if (= xyz 2)
(setq I 0)
(setq I (+ I 2))
(if (= xyz 3)
(setq I 0)
(setq I (+ I 3))
(cond
(princ co-ordsxy)
                (setq v (entnext e)
                      x (entget  v)
                          v (entnext v)
                          x (entget  v)
                (print (reverse l))
Here's a similar approach using  ssget
;;;  Create List Of 3DPOLY Vertices
(defun c:3dpv (/ en vl ss vn vd)
  (while (not en)
         (and (setq ss (ssget (list (cons 0 "POLYLINE")
                                    (cons -4 "&")
                                     (cons 70 8))))
              (= (sslength ss) 1)
              (setq en (ssname ss 0))))
  (setq vn (entnext en)
        vd (entget vn))
  (while (= "VERTEX" (cdr (assoc 0 vd)))
         (setq vl (cons (cdr (assoc 10 vd)) vl)
               vn (entnext vn)
               vd (entget vn)))
  (prin1 (setq vl (reverse vl)))
  (prin1))
-David
  (while (not en)
                                    (cons -4 "&")
                                     (cons 70 8))))
              (= (sslength ss) 1)
        vd (entget vn))
               vn (entnext vn)
               vd (entget vn)))
  (prin1))
-David
