greensock Posted October 24, 2020 Share Posted October 24, 2020 I am trying to make a robotic arm. The base is connected to rotate. Which is connected to link 2 which in turn joins with link3. Hook is attached to link 3. I want to move the links 2 and link3 up and down, but none of my constrainst seem to work and it won't let me animate it. Can you please help me out. I have also uplaoded the assembly and I used joints for the links as well. Where am I going wrong? rotate.ipt link3.ipt link2.ipt hook.ipt base.ipt Assembly.iam Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 24, 2020 Share Posted October 24, 2020 Are you using Autocad or Inventor? You posted in the Autocad Beginners section but all the files you provided are Inventor files. Quote Link to comment Share on other sites More sharing options...
greensock Posted October 24, 2020 Author Share Posted October 24, 2020 Yes I am using inventor. Sorry it was a mistake on my part. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 24, 2020 Share Posted October 24, 2020 1 hour ago, greensock said: Yes I am using inventor. Sorry it was a mistake on my part. Ok, I have moved your question to the Autodesk Inventor section. I don't use Inventor but hopefully someone else will be able to help you. Quote Link to comment Share on other sites More sharing options...
