Sign in to follow this
yotelcZ`
To find Area in Between.
yotelcZ`
Hello Everyone.
I want to find the area of  the following section as such.
I have developed a macro using Excel.
It works only as the first condition.
For some conditions shown on AutoCAD attached  it doesn't work, that is it gives the wrong Area.
Also I have shown a shaded area that it must not include.
Please help to solve the solution.
I have also included pictures of conditions. In case the AutoCAD won't work.
Thanks.
Here is the Macro containing Excel file.
Book2.xlsxdrawing.dwg
Share this post
Link to post
BIGAL
Have you looked at using Bpoly this will make a pline of the shape and can get area, you can apply a scaling factor by making it a block then change X & Y scale explode and get area. Much less code as area is a property of a pline.
Edited by BIGAL
Share this post
Link to post
yotelcZ`
Okay.
I want some how to click the following in-order using VBA.
As shown in picture I have attached.
Edited by yotelcZ`
Share this post
Link to post
BIGAL
There is some comments about BPOLY not being a vba command so try ThisDrawing.SendCommand "Bpoly" & vbCr
also ThisDrawing.SendCommand "-Boundary" & vbCr & pt vbCr  "NOT TESTED"
Lisp version (command "-boundary" pt "")
Edited by BIGAL
Share this post
Link to post
yotelcZ`
Okay how do I extract the boundary Area created??
... here is my plan...
1st .... select the boundary entity
2nd... identify the boundary as a polyline... but
3rd... find the area.
with the following vba outline
'get entity...
Dim polEnt As AcadPolyline
Dim polWnt As AcadLWPolyline
Dim ent As AcadEntity
With ThisDrawing.Utility
    .GetEntity ent, varPick, vbr & "pick the Object"
End With
If TypeOf ent Is AcadPolyline Then
    Set polEnt = ent
    x = polEnt.Area
ElseIf TypeOf ent Is AcadLWPolyline Then
    Set polWnt = ent
    x = polWnt.Area
End If
End Sub
Share this post
Link to post
BIGAL
What is X ?
Maybe
With
ThisDrawing.Utility.GetEntity ent, varPick, vbr & "pick the Object"
End With
Share this post
Link to post
yotelcZ`
X is a variable I create to assign for the Area.
It could be declared to be defined as a Double, it works without it.
Thanks.
Share this post
Link to post
Kalsefar
On 11/6/2020 at 4:03 PM, yotelcZ` said:
Hello Everyone.
Thanks.
The attached excel file doesn't showing the code, By the way I had programed an Excel file can help with your issue.
Find the attached link: http://www.mediafire.com/file/wvwftdsgbfjz1jy/IMPORT_DATA_FROM_AutoCAD.xlsm/file
Share this post
Link to post
yotelcZ`
sorry
Book2.xlsm
Edited by yotelcZ`
Share this post
Link to post
yotelcZ`
but your code has password
It's okay.
Use mine.
If you find it helpful.
Edited by yotelcZ`
Share this post
Link to post
yotelcZ`
It's okay.
Use mine.
if you find it helpful.
Edited by yotelcZ`
Share this post
Link to post
