juanragal Posted December 3, 2020 Share Posted December 3, 2020 Hi! I'm starting to feel comfortable in this forum, you always give a good answer. Thank you for your work! I want to insert new parameters in a dynamic block to set new values. I normally make atributes with an entmake method, but I never insert a parameter. I found Lee Mac's code to set or get dynamics block parameter values, but can't find anything about the created one. Thank you for advance. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted December 3, 2020 Share Posted December 3, 2020 1 hour ago, juanragal said: Hi! I'm starting to feel comfortable in this forum, you always give a good answer. Thank you for your work! I want to insert new parameters in a dynamic block to set new values. I normally make atributes with an entmake method, but I never insert a parameter. I found Lee Mac's code to set or get dynamics block parameter values, but can't find anything about the created one. Thank you for advance. As far as I know, you can't. SEE HERE for explanation Quote Link to comment Share on other sites More sharing options...
juanragal Posted December 3, 2020 Author Share Posted December 3, 2020 15 minutes ago, dlanorh said: As far as I know, you can't. SEE HERE for explanation Oh... I'm sad to read that... Ok. thank you. Quote Link to comment Share on other sites More sharing options...
