.pc3 instead of .pdf
ramimann
Hello everyone
I was plotting to pdf and everything was going perfect...suddenly this plotter started to produce .pc3 file instead of .pdf when I choose Adobe PDF as plotter. Anyone knows what's the problem?
I'm using Autocad Map 3d 2020 &Adobe Acrobat DC
.PC3 is a Plotter Configuration file, not a print file. It applies to your plotter, not your plot. You should proceed normally and output your drawing to a .PDF file.
