ammobake Posted January 12, 2021 Share Posted January 12, 2021 BOMLengths 2019.lsp I've been using this LISP over the last year (attached) and it works great for summing lengths of objects by type. But would like to modify the LISP to include a layer option from the menu similar to the one used in the thread below.. Is this possible? I would also like to modify this LISP to give you a total length in decimal feet rounded to 4 decimal places instead of feet/inches. Because of the nature of our multi-year contract we are required to estimate using a specific 3rd party vendor website. The quantity they require is almost always a decimal length in feet. Which means every line item I have to convert either manually or in excel from what the existing lisp gives me for the total. the LISP operation is pretty straightforward. command "BOM" will set it in motion - from there you specify the object types you want to sum, you then specify the selection set and hit enter to get the total in feet/inches for that object type. -ChriS Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13, 2021 Share Posted January 13, 2021 The feet inches bit may be able to be changed by changing the rtos function (rtos %1 2 2) is decimal with 2 decimal places. It is using current unit settings like feet. (getvar "lunits") The code needs to be double looped so it processes a list of layers and the objects in the (setq sset (ssget ssfilter)) where the filter is objects plus a layer. If you dont have splines and ellipses can be simplified using vl-get-length and circumference of a obj. Will try to find time but others jump in. Quote Link to comment Share on other sites More sharing options...
