Rearrange parallel polylines when changing direction
itacad
Hi, do you know a lisp that allows to rearrange parallel polylines in changes of direction?
I attach an image to try to explain better:
I apologize I had already opened this topic a few days ago but perhaps incorrectly because I do not find it
DISPOSIZIONE POLILINEE.dwg
Have something that works with fillet and does what you want the issue is that you ask for plines, I dont think it can be done directly, maybe  as a explode, fillet and rejoin yes.
All the plines would need to be open not closed.
Your example is only a simple corner what happens when something like this and redo any corner.
I understand what you mean ... I am attaching the image of the result that I would like to obtain by simulating a hypothetical command applied in the selection area delimited by the dashed yellow rectangle
Thought about this some more over a Forums/autodesk is break pline at pt so makes 2 plines can then re fillet all plines giving answer you seek.
Ok need some time to code. but got a few ideas. Any one else jump in.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/polyline-splitter-autolisp-command/td-p/10008148
My suggested method is drag line near cnr this selects all the  closest cnr points, plus gets the objects into a sorted sequence order.
Nice idea tombu but not everyone has 2021, I think the idea is do as simple as possible with least amount of picks.
I can see a problem already that as you fillet the lines get shorter look at white pline above, the fillet command can work with entity name then a point. So I have almost done the break part and testing but will need to go back to a 2 line drag solution,  3 picks for as many plines as displayed.
