Ish Posted April 30, 2021 Share Posted April 30, 2021 (edited) Dear team, I have many text that I have converted to in attribute.but every text have different tag and prompt name, no in order also. So I need a lisp program for match attribute tag, prompt name only with same order. and tag name and sequence must be same for all as per source object. I have already make attributes tag , prompt name and order , see inside green cloud. I want keep same tag, prompt name and sequence for all text as per source object. Number of tag are fix. Order of tag also fix, chainage - radius.... Speed tag in last. See the attached image. For for details. And cad file . Command : select source object for tag : command : select target object for tag : PLAN CURVE TABLE BY LAYER.dwg Edited May 5, 2021 by Ish Modified 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted April 30, 2021 Share Posted April 30, 2021 (edited) Are they always going to be in that order? what i mean is "change" always going to be the top then "radius" and so on. Edited April 30, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 30, 2021 Share Posted April 30, 2021 Is this another go at your request for road curve details that you have asked for previously. As mentioned in another post you seem to ask for a lot of freebies but never have a go yourself. Maybe have to pay at some point. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted April 30, 2021 Author Share Posted April 30, 2021 12 minutes ago, BIGAL said: Is this another go at your request for road curve details that you have asked for previously. As mentioned in another post you seem to ask for a lot of freebies but never have a go yourself. Maybe have to pay at some point. Previous post for to make block sir, For scaling purpose. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted April 30, 2021 Author Share Posted April 30, 2021 15 minutes ago, mhupp said: Are they always going to be in that order? what i mean is "change" always going to be the top then "radius" and so on. Yes sir, same order require. Order is fix. As per attach image sir 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted April 30, 2021 Share Posted April 30, 2021 6 minutes ago, BIGAL said: Maybe have to pay at some point. At least they are polite about it. just noticing the ranting system under names as well. Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted May 1, 2021 Share Posted May 1, 2021 (edited) Already solved here. You just need to do it one by one Edited May 1, 2021 by Jonathan Handojo 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted May 1, 2021 Author Share Posted May 1, 2021 3 hours ago, Jonathan Handojo said: Already solved here. You just need to do it one by one I used that lisp program but problem is that that creates separate Separate tag name sir. No sequence or order also. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted May 1, 2021 Share Posted May 1, 2021 6 minutes ago, Ish said: I used that lisp program but problem is that that creates separate Separate tag name sir. No sequence or order also. So what? There's no shortcut to get what you want. The texts in your drawing are individual, so you'll need to do each one individually. Quote Link to comment Share on other sites More sharing options...
Ish Posted May 1, 2021 Author Share Posted May 1, 2021 (edited) On 5/1/2021 at 11:41 AM, Jonathan Handojo said: So what? There's no shortcut to get what you want. The texts in your drawing are individual, so you'll need to do each one individually. Sir any lisp program for match attributes tag and prompt name only from source block tag to destination block tag, Even one by one, no problem. I have convert all text in attribute, All attributes tag and prompt name is different. I want to make same tag and prompt name with order for all block. But for follow the same tag and prompt name and order, I need to match that from source. I want to match only tag and prompt name only without change text string. No of tag are fix And order also fix top to bottom. Edited May 5, 2021 by Ish Modified 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 1, 2021 Share Posted May 1, 2021 Maybe have to pay at some point. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted May 4, 2021 Author Share Posted May 4, 2021 On 5/2/2021 at 5:29 AM, BIGAL said: Maybe have to pay at some point. I don't know what to do, this request by my friend, He refused to pay, he just looking like someone help. So I upload his request here. Thanks 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted May 4, 2021 Author Share Posted May 4, 2021 On 5/1/2021 at 5:12 AM, mhupp said: Are they always going to be in that order? what i mean is "change" always going to be the top then "radius" and so on. Any solution sir ? For tag and prompt name, with same order .text to attribute I have already do. Now remaining only to change tag and prompt name, with same order. No of text is fix, Thanks 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted May 4, 2021 Share Posted May 4, 2021 10 hours ago, Ish said: I don't know what to do, this request by my friend, He refused to pay, he just looking like someone help. So I upload his request here. Thanks Sorry pal. Nothing comes for free. What comes around goes around. You could probably get some few helps at the beginning, but I think you've reached your limit. If you want to achieve something, you need to strive to get it. If you don't put it any effort yourself, then how can you expect others to do the same for you? 1 Quote Link to comment Share on other sites More sharing options...
