0.08mm Line Weight
Elektrik
There are line weight options 0.05mm and 0.09mm, but I need chane the line weight of layer to 0.08mm. Is there any way to enter other line wieght than the standard ones? Thanks in advance.
0.01 of a mm where do you have the ruler to measure it, a human hair is like 0.1 mm. A laser printer is 600 dpi that is 0.04233 mm there is just no way you will see it your wasting your time.
  • Thanks 1
If you really, really want to see a difference, why not try an optical illusion by making the colour of the line a little bit lighter.
