Multiple selection sets
mhupp
Is there a better way to do this? only want to make one manual selection for two or more Selection sets.
Currently I am using the following.
(if (setq SS (ssget)) ;Basic ssget to select everything
    (if (setq SS1 (ssget "_P" '((0 . "LWPOLYLINE,CIRCLE") (8 . "layer") (410 . "Model")))) ;first selection
      *do stuff
    (vl-cmdf "_.Select" SS "")  ;is their a visual lisp of this command
    (if (setq SS1 (ssget "_P" '((0 . "LWPOLYLINE,CIRCLE") (8 . "diffrent layers") (410 . "Model"))))  ;second selecion
      *do other stuff
  (prompt "\nNothing Selected")
  *do stuff
  (if (setq SS1 (ssget "_P" '((0 . "LWPOLYLINE,CIRCLE") (8 . "diffrent layer") (410 . "Model"))))  ;second selecion
   *do other stuff
Edited by confutatis
I would suggest the following approach - acquire a selection set representing the union of the two sets and then use a conditional statement when iterating over the set:
(if (setq s (ssget '((0 . "LWPOLYLINE,CIRCLE") (8 . "Layer,Different Layers") (410 . "Model"))))
    (repeat (setq i (sslength s))
        (setq i (1- i)
              e (ssname s i)
        (if (wcmatch (cdr (assoc 8 (entget e))) "Layer")
                ;; Do something
                ;; Else do something
Edited by Lee Mac
  • Like 2
